What timing for drag only Carb LS1
ive got a bone stock longblock with th400 in my drag 4th gen and 3.90 gear.i also run vp 110 (consistency reasons) dont recall my timing at idle and until about 2400 and its locked out at 33*, just trying to get some more input from other people who have used these similar setups for a drag only setup. Carb is a quickfuel 750 has 40/40 squirters, power valve delete 76/76 jetting, have messed with air bleeds, and air fuel seems to be ok.the car ran 7.30's a few passes in the spring, and that was with 3.42 gear and 275/50 radials. now its on 28's with 3.90's and i cant seem to get any faster than a 7.60. i know weather may be a factor, but i dont believe its all of it. car traps about 90-91 most passes. i just figured id check timing to see if anyone saw anything crazy wrong. or had any suggestions to anythign you see.
What rpm are you shifting at? That carb is limiting you. If it can handle 40 squirteds than it can handle a bigger carb. QF makes bigger main bodys. So look into that, but your baseplate will need to be big enough too. I am running 32* at 7.0 in the 1/8!
Is the bone stock long block an LS1 ? Im confused about the 110 octane for consistency . Too much octane is a killer of performance , if the engine doesn't need the cooler fuel. In almost all instances, you will perform better with the fuel that gets you closest to spark knock, with out spark knocking. Heat in the combustion chamber is power and higher octane fuel just cools the fire. If you are convinced you need the higher octane, I would crank the timing up about 4-5*s to maybe steal some of the HP back that you lost with the 110 fuel.
Old School Heavy
A few things I can offer:
- Slicks are slower than radials. They have more roll resistance.
- Higher octane can slow you down in a low compression engine.
- Higher octane will typically need a little more timing than pump gas. Try the 100 octane unleaded race fuel.
- Race fuel can have different characteristic that will change your a/f ratio. So, you have to tune your engine on what you are going to race on.
- The weather should only be 1 or 2 tenths difference in the 1/8 on about 20 degrees temperature swing in a car like yours.
- Refine your timing with testing. I like to start at 26 and increase by 2 degrees every pass until you get the highest MPH.
Old School Heavy
We do not know the converter stall, camshaft, whether the carb is vacuum or mechanical secondary, shift points..... none of it.
This is also why E85 and alcohol have to have much larger jetting to make roughly the same HP as a gas engine. E85 and alcohol both have very low heat value per volume compared to gas, so it naturally takes more of it to make the same amount of heat ( remember, that is HP in the combustion chamber)
Old School Heavy
A lot of people think their engine needs a "950" because they see what they think are similar builds running a so called "950". What they don't know is that some 950s are actually more like 840 cfm. The Holley 950 HP is a good example. The venturis in the Holley 950 HP are the exact same size as the 750 HP. It just has a bigger base plate and profiled boosters. Most say it really flows are around 840 CFM. Now, the quick fuel 950 body is actually close to 950 cfm. It has larger venturis. Put that carb on too small of an engine at too low of an RPM and you will have all kinds of low speed metering problems. Instant PIG. Lousy 60', lousy drivability and weird a/f curves.
100% stock motor, stock cam, 853 heads, never been apart. 4000 circle d stall, my air fuels are about 12.8~ at WOT, i typically shift at 6 grand. i bracket race every single weekend, consistency is key, i agree the 110 is to much for my combo, but switching back to pump gas in the same night, netted me about the same time, i could crank the timing up, 4* but being at 38 on a stock motor seems crazy to me lol.
and i dont see the 750 being a limiting factor at all, stock motor should run with a 650. the squirter is just to get out of the hole . if my jetting was in the 90 are i would probably step up, but being square jetted in the mid 70's really sounds like the carb is about ideal for the setup.
Is the rear end getting in a bind or do you have a bad fender rub with your new slicks, did something change in the ABS brakes that is causing brake drag ?
Old School Heavy
http://www.dragtimes.com/da-density-...calculator.php
i was personally surprised the stock motor, with ebay headers, carb and stall would go that fast, but if it did it beginning of season , why cant it now. car ran in the 40's alllot! few dips into the thirtys. but regaurdless, its late september, if it was weather, i would think i would be close again weather wise
carb sounds right, think bigger tyre is killing it.
i'd step down to (or even borrow) a 255 radial, heck maybe even 235 if you got great suspension and track prep. don't think you have the hp, for 28" or slicks in general
i'd also put some valve-springs in it, rev it a fraction more, say 6400. maybe up convertor a fraction to 4200-4500.
these don't make a huge amount of hp, its a matter of getting them out the hole quick, and fractional gains to 60ft, multiple at end of track. hence small diameter radial, don't rob power and also keeps effective diff ratio.
