Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Carb spacer
Old 10-12-2013, 07:03 PM
In-Zane Moderator
ZONES89RS's Avatar
Default Carb spacer
Since myself and speed tigger have gone to a nitrous plate in favor of a spacer, he mentioned a spacer to keep heat out of the carb.
I went ahead and ordered a 1 inch cheap plastic(I say cheap yet it is very solid) spacer. I had a 2 inch spacer. So not I will have the spacer stacked under the carb and then the 1/2 inch nitrous plate.
Went ahead and just got nearly finished porting it like the high dollar CNC spacers as I did the 2 inch.
So, hope my part throttle cruise improves again like the 2 inch. It does help.
Old 10-13-2013, 09:53 AM
jaywill's Avatar
looks good..
Old 10-13-2013, 02:20 PM
Doug G's Avatar
I had thought about doing that a number of times with the 1" 4 hole spacer I had....just never done it and sold all 4 I had siting on the shelf for years (1" 4-hole, 1" open, 2" open, and a Q-jet to square bore adapter)
But what you got done looks good
Old 10-13-2013, 02:48 PM
In-Zane Moderator
ZONES89RS's Avatar
Good enough and better than 4 regular holes I'm sure. Takes maybe an hour or so. I cut it with my carbides and the finish it with cartridges as if porting and polishing heads.
Old 10-14-2013, 08:51 AM
GC99TA's Avatar
Cool! I've got the 1 inch plastic HVH atop my Big Shot plate. That combo makes good use of every last mm of my 4 inch cowl.
Old 10-14-2013, 02:48 PM
In-Zane Moderator
ZONES89RS's Avatar
Looking good!
Old 10-14-2013, 03:03 PM
fast89stang's Avatar
I talked to the Holley rep, and he said my big rectangle port heads would probably really get some help from a 4 hole under the carb, what you guys thin? He said the signal is weak with my 950 ultra hp carb, and it would help the signal alot. I have a spacer alot like yours zone.
Old 10-14-2013, 05:23 PM
In-Zane Moderator
ZONES89RS's Avatar
I would do it if you have the hood space!
Old 10-14-2013, 07:27 PM
In-Zane Moderator
ZONES89RS's Avatar
Low speed driving feels better now. Like before will less hickups at cruise, none at all really.
Old 10-14-2013, 08:34 PM
jaywill's Avatar
good info,,how do u think a open 1 would work ???
Old 10-14-2013, 08:50 PM
In-Zane Moderator
ZONES89RS's Avatar
Should increase velocity, but the 4 hole I think makes an even smoother transition from the venturis. This is all just an assumption but makes sense.
Old 10-15-2013, 09:32 AM
jaywill's Avatar
It does..
Quick Reply: Carb spacer
