LS Pinging
Doesn't make any sense. The car is over half the weight of the truck the engine was pulled out of. Maybe a different heat range plug? Any suggestions would be helpful!!
Something I noticed this morning is it doesn't do it when the engine is cold only when hot.
Try running with a lap top plugged in and see what timing the box is actually putting in when it pings.
Carb tune can affect pinging also. How sure are you about your carb tune, have you check AFR with a wideband?
And detonation is going to be more prevalent when the engine is hot.
And for the carb tune, I am not sure about it at all. Took it out of the box and installed it. I dont have a wideband to check AFR...
It would help to know what you have ,but a good starting point would be something around 12-14* at cranking RPM, then ramp it up to around 28* by 2000. A dip of a couple degrees is a good idea at peak torque and that will be determined by the cam profile the engine is running. I like to have the dip last for about a thousand RPMs, then ramp back up to the max timing.
That is a very conservative # and there is a good chance the engine will want more peak timing, but the only way to figure that out is with some sort of repeatable testing. Drag strip or dyno. If it is pinging, back the timing off a couple degrees at a time. A good , but dangerous way to determine where the peak torque is, would be to set the timing straight across at , say 32*, and go for a blast, watching the tach . The RPM that the engine pings at should be the max torque RPM. Back the timing off in that RPM range a couple degrees. You now have a pretty good curve for your engine. You can move that curve up and down to find the best all around timing setup for your particular combo.
Be conservative and use caution while testing, or a new set of pistons may be in your future.
Its a bone stock LQ4 out of a 04 Suburban. The intake is a Edelbrock Performer RPM and the carb is a Holley 650 DP out of the box.The transmission is a 6-speed, 4:11's in the rear.
I'm having trouble around 2000rpm. I can get a screen shot in a bit. At this RPM the timing is at 30 degrees, with 6 coming in from the MAP curve. I do not have the MAP sensor installed. I've also tried running 93 in it, but that didnt help either. I seem to notice most of the trouble in 5th and 6th gear. Maybe I just cant hear it in the lower gears?
But, until then, put in a custom timing curve and see if that cures your problem. Try a timing curve like this:
0 to 300 RPM 8 degrees
300 to 2400 RPM 16 degrees
2400 to 4000 RPM ramping from 16 degrees to 30 degrees
4000 to Infinity 30 degrees
See if that works for you.
Don't move the MAP table from 0* until you get a MAP sensor, then ask someone else how to set up the MAP, like SpeedTigger, because Im still getting my head wrapped around the whole map thing, LOL.
I don't see any reason to trouble shoot the curve in the no 1 pill and you should just pull it out and throw it away. Use the lap top for all your tuning and throw all the chips away or give them to someone that doesn't have a lap top.
Car is still making the same noise. Even with the new "map" and 93 octane, i'm still hearing some noise.
Side note, when first driving the car, at temperature, I dont hear anything. It seems only in 5th and 6th do I hear something after I have been driving for awhile.
Is there anything in the transmission that may cause a similar noise? I've listened to this enough that I cant point a finger at anything else.
Loosing my mind on this, I need some help!
Another note, I am getting this "sound" going downhill just as well. Heck I'm hardly even touching the gas....this is why I'm confused as too how it can be still pinging. Shouldn't this be happening under a load?
So I spent some time on the phone with the guys from D&D Performance. Apparently there was a TSB issued for viper transmission concerning noise in 5th and 6th gear. I explained the entire story and they seem to think this is what I'm experiencing. What seemed to convince them further was the fact the being in 5th going downhill, running reduced timing and 93 octane I shouldnt hear any pinging when lightly stepping on the throttle. They gave me a recommendation on what fluid to run so I'm going to try that route.
If anyone has any additional incite, I would love to hear it!
