What factors into throttle response?
I was watching the video in dmracing's thread. That thing had awesome throttle response. What contributes to such good throttle response? Is it the carb's tune? Engine's compression? Flow of the heads("lazy" L92's vs cathedral or other)? Converter/flexplate combo? Cam/valve events? Ignition timing?
I'm just curious. Most of my motors seem to rev a bit late and lazy.
The carb is the main shabang. The tune. How fast it can deliver the proper amount of fuel and air when the throttle is blipped. From there, the incoming air charge and compression as well as all the spark location and quench. The more effective all that is the more a small or smallish cam becomes really snappy. Then lighter weight components such as valves and lifters and then rotating assembly, then on to felxplate/flywheel and converter/clutch. The lighter the better when making a engine rev. In gear or free revving. Larger cams will wrap faster on the higher revs.
It must be my bad carb tuning that's messing up mine. All my combos have had crappy throttle response...my LQ4, LY6, LM7, and my L33. I've used different carbs on them, also tried the different timing pills(even ran full timing from 700rpm). It always seems like a big delay before they realize the throttle has been opened. Kinda have to hit it twice or just hold it open.
Timing and carb calibration are the things you can control now that the motor is built. Make sure you have around 20 degrees of base timing, make sure you have enough squirter and proper jetting. Get those things right and I bet she lights right up for you.
I even threw some extra timing in mine about where I stall to on the line, it helped, especially once i got the right squirters. If you have the ls3 heads, they seem to love fuel ALOT!!!!
Dangit! I think I just found a good portion of my "fuel" problem. The foam in the cell fell apart. I just thought I had valve float on the topend or something. My pre pump filter is full of this crap. My pre-carb filter should have kept the carb clean, so maybe I can still start it with fresh gas in the bowls.
