Which direction with build?
I'm on the fence with whether I want to go LS in my 72 Buick or stick with a big block build. My goal is a driver that will run in the 11.5-11.7 range on motor. If I go LS I will more than likely install a nitrous setup. The biggest concern I have is how well I can overcome a heavy car with a motor that specializes in top in power. I don't want the car to die out of the hole. I also don't want such a large cam that I can cruise. Also, Im pretty sure that I can make more power and be more reliable for less money than the Buick build.
My first thoughts were to go all forged 408 cubes with LS3 heads. Obviously with an intake (Victor Jr?) and carb (750 HP?)
Am I even on the right track? Any suggestions? Realistically how much should this cost?
Thanks guys!
BUT, in the ET range you're wanting, I think you may be better off with a 455 Buick. I ran them for years. Stock bottom end, Stage 1 heads, C113 cam, B4B intake and decent converter I ran 11.50's in a full weight (3800 #) 72' Skylark
I've got a call into a buddy now, he has a Skylark with a 6.0 in it that ran 10's in a Mustang, not sure if he's taken it to the track with the LS setup. I'll report back lol
Decisions, decisions...
Im running a crate LS3 with a cam that me and Tim at Bullet Racing speced out w 220-230 at .050 on a 108+4 w 629 lift on both sides. That and a GMPP dual plane intake and 1 7/8" long tubes rounds out the setup.
The biggie for me on this engine is, I can cruise easily at 55mph and 1750rpms with the converter locked ,up and down the rolling hills where I live. It pulls down at that RPM without a hint of lugging. It also pulls enough vacuum to run my big power brakes that need 16" of vacuum to run right. It will buzz straight to 7000rpms without any seat of the pants drop off.
With more cubes, in your Buick, That formula should easily get you to mid 11s performance, without taking any low rpm cruising ability away.
Its not the popular choice on cam design or the intake choice, either, But the numbers don't lie. This combo will give you a cake and let you eat it too, period.
496 bbc....10 to 1
781 large ovals...mild port work...2.19/1.88 valves
RPM air gap dual plane
Holley HP950 street
241/249...625/625...110 hyd roller
1 3/4" mid length headers (needs larger+longtubes)
3" exhaust
TH400....2400 stall
3.73...28" DR
Mech fan/power steering/power brakes
Only at track once went 11.8 at 117.9
No offense but putting any non buick engine is heresy in the buick world....and a BBC is the greatest sin! I just couldnt do it
Lol...its ok for a LS but no BBC?? I love LS stuff but for heavy rides like yours you gotta love big cubes. Mild gears and mild stall...low rpms...still run hard.
The formula is pretty simple on paper and I proved the formula doesn't have any real tricks to work. I went with the same IDEA on camshaft and used the stellar GMPP dual plane intake and LS3 heads. Power is always right there, from off idle to 7000rpms. If you have the funds, I would do a 416 with the same formula of low 220s at .050, aggressive lobes w lifts in the 600 range to take advantage of the flow on the LS3 heads. D&As cam in the 409 had 224 at .050 on a 108+6 LSA. I didn't want to get that aggressive on lead, so I did 108+4 and it works great. The GMPP dual plane can move all the air you will need at upper RPM, BUT the long runners make for some great torque down low, as you can see from D&As TQ #s.
I hope you go this route because I think it will fly in your Buford and not take away a bit of street drive ability. Good Luck !!
Maybe Im looking at the wrong build of theirs
Here you go. Enjoy!! My numbers were off slightly, but my memory isn't what it use to be and its been a couple years since I looked at it. They are 533 at 2500rpms and 581 ft lbs at 3200 max TQ. HP was 588 at 5800rpms. Look at the torque curve. I feel at same thing with my abbreviated , much simpler build. Over 500ft lbs from below 2500 to 6000rpms !!! That's a special engine combo ! The secret is short duration, a lot of lead with aggressive lobe profiles to get high lift numbers, LS3 heads to carry the HP and TQ at the upper RPM range and the GMPP dual plane to flatten the torque curve. Also notice the peak HP is at 5800rpms , BUT it still has 564 HP at 6400 rpms ,where the pull stopped. It just keeps on going in the TQ and HP curve. No need for deep gears , high stalls, or a super light car to make power you can use everywhere.
My ultimate goal is mid 11's on motor and anything on the bottle is a bonus.
Like I said before, Im still planning out my build and doing research on things but I really appreciate all the help Ive found on here. The idea of a dual plane intake is something I had never thought of since most magazine builds are strictly after peak HP numbers. Flattening the curve should really help the car be more streetable.
