Harder Nitrous Launches Coming Soon.
#87
I was very impressed at how quickly he turned it around. And his new staff member Tammy did a great job at communicating. It was a far superior experience compared to the initial order. I am very glad he has things flowing. I am eager to test this thing out!
#88
That's great to hear. Its hard to recommend someone all the time that gets bad reviews on time lines. I have pushed a lot of potential customers his way, but have always told them to be patient because it might take a while. Im sure you will be very happy with it. On mine ,I had to rig an overflow can because it blows fluid out the overflow at the top of the trans. I like to keep mine a quart or so over full, to help keep the fluid at the pickup under hard acceleration . Im also using one of Lonnies sheet aluminum pans with the big bottom feeder filter. These are all tricks I picked up doing research on the 2004Rs. With the standard filter and pan, especially if the fluid level is at normal level, you can get fluid pressure drops on hard acceleration . Do that too many times and it can cause clutch and band damage and slip.
#89
#91
![EEK !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_eek2.gif)
#92
I haven't run a 200R4 since 2003.It was in a GN that ran 10.3s with 60' times in the 1.4s,with a transbrake.We ran the trannys at stock fluid levels.To stop the filter from sucking air on a hard leave we would silicone the top sealing edge of the filter.I guess over filling the trans to keep the filter submerged is doing the same thing.I don't see any big advantage to running a deeper pan,unless the filter was extended.
#93
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#94
Running a deeper pan will not help with an overheating problem.The extra fluid capacity only delays the heating of the fluid.If your trans overheats then get a bigger cooler.Getting the cooler in line with direct air flow is critical.Adding a puller fan to the cooler on a fast transbrake car makes a big difference on the line.
Ken Seggie
National Performance
8.74 @ 158
Ken Seggie
8.74 @ 158
#95
Ken Seggie
8.74 @ 158
Ken Seggie
8.74 @ 158
Im just sharing some knowledge with Steven that I picked up after pouring over 6 months of research on the Turbo Buick forums and talking to the best guys in the 2004R building business , Lonnie at Extreme and Dave Husik of Turbo Buick.com, and I also bent Jakes ear on the little trans too. Im very happy with the trans Lonnie built for me, as is Steven(SpeedTigger) with his Extreme 2004R.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#100
I wore my little wire welder out. Maybe Santa will bring me one. I doubt it though. I have a one way valve for my fuel line and a prop valve for the rear brakes at the top of the list and I doubt the money will go further down than that, LOL. The kids are covered though and that's what its really about anyway.
