Beater build s10
Yeah ive got the brp 1-7/8 lt set. Make sure you take the collector all the way off when you put it together... kinda a no brainer but I didnt and it was a pain in the ***.... also unless you have tubular front suspension the upper control arms will hit the primary tubes if you bottom out. Make sure your bump stops shut that issue down. The ceramic coating looked awesome the first year but some corrosion from the winter some how made them look rusty. Im running stage 8's for my bolts and havent had a issue on leakage yet. Good luck and keep the posts coming!
Mine come all the way past where the trans mounts just a hair so they are definately longer than most. Im fixin to take the collectors back off and tig some v band clamps on for easy hook up. Im not much on just the band clamps
I like the side exit idea. I cut a hole in my frame, used a 3.5 inch by1/4 inch thickness tube and boxed it in for the exhaust pipe to come out in front of the wheels. It should look wicked. Will be tough to get an x pipe just right but Im gonn try it. 3 inch all the way
