Beater build s10
#225
Yours won't be as fast as a baby cam 4.8? Damn.
Any how, motor mounts are in. When weather is where I want it to be I'll start taking the 94 gmc apart and then the s10 transplant will begin.
I need to find a tarp for the mustang since it will be sitting outside for a little bit. Or I can pull it to my house and put it in the garage....I like that idea. Damn 4 wheeler needs a battery.
#226
Mine is a BONE STOCK 5.3 with the conversion headers, hummer oil pan, and carb swap over. The only way I would beat you is if you ran naturally aspirated and I ran my nitrous kit. Plus I weigh in at a good 475, where I am pretty sure you run a bit less than me. So you already have a weight advantage.
