Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Beater build s10
Old Feb 25, 2014 | 01:24 PM
  #361
ZONES89RS's Avatar
In-Zane Moderator
Lol, right, I'm so over being behind on the project I don't want to waste my time.
Old Feb 25, 2014 | 05:45 PM
  #362
ZONES89RS's Avatar
In-Zane Moderator
Should have a 4.10 limited slip rear tomorrow.
Old Feb 27, 2014 | 09:31 PM
  #363
ZONES89RS's Avatar
In-Zane Moderator
Got my shifter ball on the way. Score. Lol
Anyway, I did order my speed hut GPS speedo. Had right and left blinker indicator and bright light indicator. Cannot wait till I am at the point of installing it and the other gauges.
Old Mar 2, 2014 | 01:08 AM
  #364
ZONES89RS's Avatar
In-Zane Moderator
Got some damage done today. My buddy joe is in from San Antonio and we got things goin. Had to pull the motor one more time and do some more adjustments on the headers and mounts but after that, Trans went in. Might be close to using the stock drive shaft length as well.
Will be modding the console to fit the shifter. So things are looking great finally. The shifter location is great.
Old Mar 2, 2014 | 02:49 AM
  #365
BigEd_72455's Avatar
How is the rear clearance once you have it in 2/4/6?? Think about putting a slight forward tilt to the arm?
Glad you got it this far. Looks like both of us are making some real good progress.
Old Mar 2, 2014 | 09:40 AM
  #366
ZONES89RS's Avatar
In-Zane Moderator
It looks ok, I was originally thinking I should bend the shifter forward because I thought it was going to be further up. Once the shifter **** is on and everything is together, I'll make adjustments as needed.
Doing it the way I did was easier than picking the cab up, was able to install the Trans, make the marking for where to cut, then pull the Trans back out and make the new hole and then get it back in. It was easier than my 3rd gens to get the 6 speed in and out. An automatic I think would be easier to lift the cab but you wouldn't have to cut a hole in the floor either. Lol
Old Mar 2, 2014 | 10:35 PM
  #367
ZONES89RS's Avatar
In-Zane Moderator
Trans is officially in, modded the stock X member. Chop,cut,rebuild. Exhaust routing should be simple. Easier than my third gens.
So, for gauges, I was going to use some flat aluminum and they didn't have any at tractor supply, but they had diamond plate aluminum. Got it mocked up in the location I like, what do you guys think?
The other thought is to paint it black maybe.
Old Mar 2, 2014 | 11:57 PM
  #368
Blindingly ugly!! Sorry dude.
Scrap it and go with simple flat black plastic panel. WAY easier to cut and shape, plus cheaper!!
Old Mar 3, 2014 | 12:13 AM
  #369
Sumter's Avatar
Agreed, diamond plate is extremely ugly
Old Mar 3, 2014 | 07:33 AM
  #370
ZONES89RS's Avatar
In-Zane Moderator
That's why I was going to paint it black.
And it stays, the metal was not free, so scrapping it is not an option. Lol
Damn Ed, for someone ding an S10 swap you sure take the easy way out on a swap that is not exactly easy. Lol
Old Mar 3, 2014 | 11:37 AM
  #371
Yeah, I left my working gauges in the dash...
I don't have the money to buy a custom dash kit.. I want mine RUNNING and driving down the track, and for that I need water temp, oil pressure, and voltage. Everything else is actually unnecessary but I got a tank with a sender to work with my dash gauge so I could keep an eye on it without possibly contaminating the gas in the tank with trash.
Old Mar 3, 2014 | 11:39 AM
  #372
Being yours will be street driven, you need more stuff on yours.
Old Mar 3, 2014 | 11:41 AM
  #373
Why ask what we think if you already know its gonna stay? YOU are the one who will be driving it, not us... Set it up for what YOU want... OUR opinion is just that, OUR opinion..
Old Mar 3, 2014 | 12:34 PM
  #374
ZONES89RS's Avatar
In-Zane Moderator
It was a like or dislike and not really a "hey, I have no clue what to do do let me take suggestions". Pretty clear. And input on if anyone thought I should go ahead with painting it black.
Old Mar 3, 2014 | 01:22 PM
  #375
snook's Avatar
It will look fine once its done. That being said, I would make it brushed looking instead of shiny. Take a scotch pad and see how it turns out on the back side of it. Or some wrinkle black. Wrinkle black fixes everything lol
Plenty of them in here
http://www.v8s10.org/forum/viewtopic...guages#p273804
Old Mar 3, 2014 | 02:16 PM
  #376
TXsilverado's Avatar
i think it will look fine once you get the gauges in it. there wont be much diamond plate left at all. satin black or a gray that matches the dash.
Old Mar 3, 2014 | 03:12 PM
  #377
ZONES89RS's Avatar
In-Zane Moderator
Yea, exactly, I was not digging the shine just the pattern.
And I didn't even think of the wrinkle black, that's what I'm going to do. Wrinkle finish on the diamond pattern will be sweet.
I usually do my valve covers with that stuff, so idk why I didn't think of it! Lol
Old Mar 5, 2014 | 04:11 PM
  #378
ZONES89RS's Avatar
In-Zane Moderator
8.8 explorer rear with 4.10s. Not LSD though, so not sure if I want to weld it or figure out a limited slip setup since it is a daily.
Old Mar 5, 2014 | 04:31 PM
  #379
Grab you a mustang 8.8 LSD off ebay for fairly cheap... check if it needs clutches and toss it in with new bearings all through the unit and you have a strong and reliable setup.
Is that rear 28 or 31 spline?
Old Mar 5, 2014 | 05:05 PM
  #380
i say put it in, drive it and worry about a LSD later. or pull out that miller 211 and fix it speaking of that miller 211...you should trade me that welder for the new colt ar15 that i sent you a picture of
