cooling my carb 5.3 s10
I have a 2.5 inch thick dual core all aluminum radiator and need fans the radiator is small so its hard to find dual fans for it. I called jegs and they told me to get this or a setup like this but it seems like the cfm is too low what you guys think? http://www.jegs.com/i/Jegster/550/40534/10002/-1?parentProductId=
Today I scored a pair of fans that'll snap together and have like a molded shroud there 2 speeders together they flow 4000cfm but only one alone it flows 1500 and doesn't have much of a shroud shud this suffice? And if it wasn't quite enough cud I run it on the pass side of the rad and mount a.pusher on the driver wud this work?
Heres what im using and I dont even run the fan unless im in traffic or doing burnouts.
http://www.ebay.com/itm/16-Street-Rod-Radiator-Electric-3000-CFM-Fan-Reversible-Heavy-Duty-NEW-250-W-/270996600203?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f18a7f58bhttp://www.ebay.com/itm/NEW-ALUMINUM-RADIATOR-GM-CHEVY-19-x-26-DOUBLE-PASS-/390260076198?hash=item5add502ea6But what you scored will work fine. Just make sure you get the coolant filled and bled good or a hurricane wont cool it.
I am running stock 4.3 radiator with a single 16" fan from oreilly's. 1 year warranty and it was only $86 for the fan. With this fan though, you do have to move the radiator forward if the swap mounts use the 2.8 motor mounts. Engine sits about half an inch too far forward. At least for mine it did.
Interepid fans work great on smaller radiators, and can be found easily at the junkyard. Or mine on ebay new for 90 bucks. They move a ton of air. Chrysler concorde has the same fans too. Fits my s10 conversion radiator nicely. I believe they are 26 X 15 best I remember
![](http://i30.photobucket.com/albums/c346/09181999/radiator2_zpsfa2b787d.jpg)
Or here is the ford taurus fan on the same radiator. Just know that it blows awesome but draws a lot of amps lol. Its small but is the strongest fan Ive used
![](http://i30.photobucket.com/albums/c346/09181999/100_0363-1.jpg)
Forgot to add, I am using the stock overflow tank as well.. Still bolted to the fender. If it works and it stays out of the way, why not use it?
For me its not about being a fashion show under the hood, its about it working and working well. Might be uglier than my old ***, but it works.
Only pic I had of the taurus fan lol. Long time ago too
Stock overflow tank here too. I took some aquarium rocks and bleach to clean the inside if the tank, outside I used bleach and a scotchbrite pad on the outside. Looks like new. Works fine
Want to see what it looks like and how clearance you still have!
Waid
Thanks.
![](https://i30.photobucket.com/albums/c346/09181999/radiator2_zpsfa2b787d.jpg)
![](https://i30.photobucket.com/albums/c346/09181999/100_0363-1.jpg)
