oil pressure sensor location blocked
I see DOD oil feed galleys
I wonder if someone did what I did and plugged the port off so as to prevent oil pressure loss through the solenoids and or cover gasket?
I just drilled and tapped my oil cooler bypass for 1/8" npt to get oil pressure
IF it's threaded in and can be extracted TIG welding a bolt onto the obstruction WILL get it out.
But something doesn't look right with the pic. To me it doesn't look like a broken anything as the machine marks I can see are across the blockage and face of the block.
The "drive" part is. But the rest of whatever is in that hole was milled flush. If you really blow the pic up you can even see "it's" outline in the face of the machining.
I don't think its a broken sender. Chiefly because on a DOD motor the sender is threaded into the cover and not the block
