blow-thru jetting.? ??
- these are needed to get enough fuel enrichment once boost comes in. If you dont use these, you can jet up enough to get in boost A/F's in check, BUT A/F's will be very rich in almost all other operating ranges lees than full boost.
Vent tube extensions - some carbs need to have the bowl vents xtended to ensure boost pressure gets into the fuel bowls.
There is ALOT to it. I dont know it all, but the BEST advice I can give you is to send your carb to CSU, or buy a complete carb from him. Yes it costs a few bucks, but Kevin's carbs work flawlessly. Mine drives excellent out of boost, and maintains a nice flat A/F in boost.
