Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Neanderthal Carb Guy BS Thread
Old 11-22-2017, 03:41 PM
  #1781
jerr6's Avatar
Originally Posted by speedtigger
Front is all stock with Viking double adjustable shocks
Rear is stock location with TRZ Motorsports chrome-moly double adjustable control arms, control arm mount brace, Viking double adjustable shocks and a street sway/anti-roll bar from HR Parts.
The street rear anti-roll bar is a weak link on the drag strip as it is designed to flex, but I drive the car on the street a lot so...... With that said, I have still gone 1.29 60'.
thanks! i have a A-body also. I'm always interested to see what people are running. I am putting more focus on my suspension this year.
Old 11-22-2017, 04:48 PM
  #1782
Old School Heavy
speedtigger's Avatar
Since I'm going forced induction, of course my carburetor won't cut it anymore. So, here's my solution.
Neanderthal fuel injection!
Old 11-23-2017, 09:33 AM
  #1783
In-Zane Moderator
ZONES89RS's Avatar
Happy turkey day gents!
Old 11-23-2017, 09:40 AM
  #1784
Doug G's Avatar
Happy Turkey day to you and yours as well
MMMmmmmm
Neanderthal Carb Guy BS Thread-2017-fried.jpgdamn sideways pics
Old 11-23-2017, 03:51 PM
  #1785
Received 3,039 Likes on 2,366 Posts
FRIED bird is GOOD bird!
Have a great Thanksgiving!
Old 11-26-2017, 12:48 PM
  #1786
jerr6's Avatar
Front suspension question. I figure I'll ask here since it seems like majority of people here race. I have 71 chevelle with cheap 90/10 shocks and trick springs rated at 242 lb in. The trick springs have been in a couple months now. After the springs installed the front end came up a lot easier at launch. But my front ride height is really tall. I can barely move the car by pushing down on it. So I'm wondering if I need to go with softer springs, shorter, or keep what I have and just cut some coil off. Reason I'm asking also is my buddy has trick springs and 90/10 shocks in his Camaro and his can move up and down fairly easy just by pushing down.
Old 11-26-2017, 03:02 PM
  #1787
Does your buddy's springs have the same rate?
Old 11-26-2017, 03:15 PM
  #1788
jerr6's Avatar
Probably not. When I felt how much movement his had it got me thinking maybe mine is wrong. Was only 2 choices in spring rate for my car
Old 11-26-2017, 03:38 PM
  #1789
Did you take the harder ones? Just out of curiosity.....
Old 11-26-2017, 03:48 PM
  #1790
jerr6's Avatar
No. Small block springs. I'll might keep the springs and just cut a little off for ride height and get some decent 90/10 shocks then see how it moves
Old 11-26-2017, 03:58 PM
  #1791
Doug G's Avatar
Stock Z-28 replacement springs here and Comp 3-ways set to 90-10....front end moves nice.
One thing I have to ask is, when you installed the springs, did you tighten everything while car was in the air with no weight on the tires ?
If so, this can cause a bind, which can cause the same issues you're having
Loosen everything up some and take a slow ride around the block to let it settle, then re-torque while it has weight on it.
Old 11-26-2017, 04:29 PM
  #1792
jerr6's Avatar
I only took apart upper ball joint to change springs out. Maybe I'll disconnect shocks and see if it moves any easier and go from there.
Old 11-26-2017, 04:31 PM
  #1793
jerr6's Avatar
I think it might be just too high spring rate.
Old 11-26-2017, 05:15 PM
  #1794
Doug G's Avatar
Oh, and cutting a spring to lower the ride height will increase the spring rate some....depending on how much is cut.
1/2 coil is about 1
1 full coil is about 2-2.25"
Be sure, if you do cut, to use a cut-off wheel...do not use a torch.
Old 11-26-2017, 05:24 PM
  #1795
Doug G's Avatar
I looked it up...yes, 240+ are BB springs.(or so it looks)
Old 11-26-2017, 05:54 PM
  #1796
jerr6's Avatar
i was also thinking if i have to take those trick springs back out i might as well get different ones. they were nerve racking putting in. felt like the compressor was gonna break at any second lol. maybe i ll try those santhuff springs in 225 rate.im sure they can help me pick.
Old 11-26-2017, 09:19 PM
  #1797
GC99TA's Avatar
I ran trick springs in my Camaro for a few years. Mine had to be cut to achieve proper ride height. Going along with what Doug said about tightening the A-arms.....I never really tighten mine down at all. I double nut the bolts and lock them together so I'm never pinching the A-arm and causing a bind. Also remember that a 90/10 shock SHOULD be hard to push down on to a point. They should extend easily and be tough to compress.
Old 01-09-2018, 12:10 AM
  #1798
TXsilverado's Avatar
Happy new year.
Old 01-09-2018, 08:12 AM
  #1799
Old School Heavy
Happy 2018 to you Stewart!
Old 01-09-2018, 04:25 PM
  #1800
Doug G's Avatar
Happy New Year Stewart
Quick Reply: Neanderthal Carb Guy BS Thread
