347 nitrous carb build, come on in !
finally gtting back out in the garage to get my 347 back together, now ive been rubbed the wrong way by my tuner when it was fuel injected and the tune always sucked dogs *****, so I said screw it ill slap a carb on that bitch and tune her my self and this is where iam at,
how much rwhp you think iam goin to make?
1998 transam
ls1 347 CID
stock crank w/ arp main studs
ls2 rods w/ arp bolts
king bearings rods/mains
mahle power pack forged pistons
akerly & childs nitrous rings
slp melling h/v oil pump
slp adjustable double roller timing chain
g5xx cam
dura bond cam bearings
prc ls6 2.5 cylinder heads 60cc chambers
gm mls head gaskets
arp head studs
manley valves
prc gold valve springs
jesel j2k 1.7 rocker shafts
comp R lifters
comp push rods
edelbrock super victor carb intake
pro systems holley 4150 750cfm carb
msd 6ls ignition
lingenfelter 2 step
NOS nitrous plate
transmission in now a th400 currently being build by me also. with a freakshow 4500 converter, moser ford 9'' rear currently 4:10s gunna change to 3:73s, 28'' mt drag radial
1998 transam
ls1 347 CID
g5xx cam
gm mls head gaskets
arp head studs
manley valves
comp R lifters
comp push rods
msd 6ls ignition
lingenfelter 2 step
NOS nitrous plate
Old School Heavy
That is some serious business there. I am not much of a wheel dyno guy, but I would have to think that would be near 500 RWHP even through that high stall. But, the real story on that bad boy is going to be what it does at the strip when you spray it. I look forward to seeing what it does. Love those pro series Jesel rockers. How much they hit you for those?
your reasoning to go to a carb instead of staying efi is the exact same reason i made the switch also. i had bad experience after bad experience with multiple tuners and realized i'd never be happy. to sit down and learn the EFI tuning game at this point isn't an option. i'll get around to it one day for mild builds, but for this kind of stuff, i'm sticking to the metered fuel leak.
i know of a forged 384 that was making almost 700rwhp on a mustang dyno spraying 2 kits in a c5 6 speed vette. Im forging my 346 in my 90 mustang lx righ now with diamond dome pistons & shooting for 12.5 to 1 compression.I plan on spraying 2-300 with a nitrous outlet puck. keep us posted on how it does.
I think where on the same page lol, i bought the rockers used from a guy on here, I think 700buks i paid, and I actually broke a jesel rocker on the street down in ocean city Maryland that ruined my weekend , I believe I had the jam nuts locked down to tight by hand, so I torqued them this time around, and yea cant wait to get to the track with it
Very nice build you got going there. Should be a screamer. In for results.
