need mad info / thoughts....
Ok I'm back in the LS game. Been gone for a couple of months and found out Ford = JUNK. Im not 100% ignorant when it comes to these motors but I'm actually going to try and build one (with factory parts) that better than the last one.....
https://ls1tech.com/forums/carburete...rous-guys.html
Yeah I traded the car off for a Ford and after extensive research have come to the conclusion that fords are junk. (Unless making a cleavor but thats another thought) Anyways im rambling now and heres where I'm at....
Yep a 68 Ford Mustang and I'm going to bastardize it.
Heres where I sit now..
Lq4
799 heads
Ls2 floating rods and pistons
Following? Iron Ls2
I have a tsp228r cam showing up.
A powerglide will move it (bought a brake for it also)
And of course my big shot plate will be used
Heres my questions..lol
1) What should I use for an intake? (Single or dual plain)
2) Is this motor going to be enough to get up and go with the transmission being a 2 speed?
3) What fuel pump should I use to power both the carb and solenoid?
4) lifters? Ls6 or Ls7? Will the Ls7 need a different push rod?
5) What sized carb? Im pretty sure the 650 i bought for the 302 is not going to be beneficial.
6) Is there anything I need to address?
Thanks for your time. John
Lq4
799 heads
Following? Iron Ls2
Old School Heavy
Lq4
799 heads
Following? Iron Ls2
Also, if you plan on having a stall converter of 3500 or above, I would go with the single plane.
In a street car with lower to moderate HP levels, a glide can be doggy to drive around. The low numerical first gear ratio will create more slip in the torque converter too. This can make for a very poor driving experience for a street car and slower ETs if the car does not have the power to weight ratio to make it work. Also, a glide with require a higher stall RPM to work off of the nitrous
Same lifter. The "LS7 lifter" has replaced the standard lifters, so they are all the same now.
That camshaft will be fine for general duty if you are getting it cheap, but if you plan of spraying this thing 200 or better, I would get one with some more exhaust duration. Also, with that camshaft, I would install it on a 107 to 108 ICL. It will work with the single plane manifold better advanced a little.
Old School Heavy
If your combo is all about the spray, I would run that 235/243 113+4 for sure. Off the spray, it might be a little doggy on the launch, but on the giggle juice that won't be an issue. Just make sure you are clear with your torque converter guy with what you are doing. The stall converter choice will be important.
What do you think the chances are to not have to flycut? Ive ran a bigger duration before (without flycutting) but not this amount of lift.
The last 5.3 with the trex inspired cam was pretty doggy off the juice. Expecially with the 3.55 gears on 28" tires. Im going to try to stay with a 26" tall this time.
Also the guy "freakshow performance" on ebay sounds pretty good, ever try them? Theres a mega thread on the bullet about them.
Old School Heavy
IVO is 8.5 ° BTDC
IVC is 46.5 ° ABDC
EVO is 58.5 ° BBDC
EVC is 4.5 ° ATDC
Overlap is 13 °
That cam should have acceptable valve clearance as long as you don't mill the heads more than .010". But the saying goes: Check it, so you don't wreck it.
As for the torque converter guy you mention. I don't know. I use Circle D for my lock up stuff and I have friends who have great success with PTC for the non lock up stuff.
A little update.. I went with the big cam and also put together a powerglide. The glide is not 100% done (needs valve body) but the 6.0 is. Unfortunately I'll have to cut a hole in the hood. Between the vic jr and the nitrous plate i will not be able run an air filter. (Even with a 2" drop base and a 1-3/4" filter. Thats ok ford made a scoop thats been been manufactured in the aftermarket.
Old School Heavy
However the Quick Fuel 750, 850 and 950 carbs are actually just what they say. Their venturi sizes actually increase proportionately. So, that recommendation should have just been for a Quick Fuel 750 Q series for what the OP is doing.
While I have not held one in my hand yet, I think the new Holley Ultra series are true CFM ratings also.
They are still are off. But now they go the other way. The Ultra HP 950 actually flows 1025 cfm. Not sure about the 750, and 850.
