Road Race Ls1 Dry sump Carbureted
Building an engine for my road course late model
It's an ls1 out of a 97 corvette, trying to keep it somewhat budget
So far I have
Probe FPS forged pistons
Scat I beam rods
ported 862 heads with pac 1905 springs
Ati Balancer
650 double pumper with choke horn
Moroso 3 stage dry sump
Champ dry sump pan
Clevite H bearings, cam bearings, total seal rings
Need to figure out what lifters I'm going to use, It seems like the morel drop in lifters are pretty decent. Will be shifting before 7000 rpm, probably around 6500-6800
Also thinking about running a dual plane intake, maybe the holley
I need to plug the factory oil pump galley up also for the external dry sump
Will be getting a custom ground cam.
Flow sheet for heads
The accessory mounts I've made so far
And dry sump mock up, not sure how I'm going to mount it yet. Have HTD pulleys now
So far I have
Scat I beam rods
Ati Balancer
Champ dry sump pan
This pump should be standard rotation
Like this
http://www.wegnerautomotive.com/data...9_1152x576.jpg
Like this
Yeah, I was fairly certain all the stewart pumps like this are standard rotation, might need to verify though as I bought this used
It was weird though, it wouldn't fit without spacers, I ended up with 3/4" spacers, but that was to space everything out to have enough clearance. I think it may have been milled for a motor plate
I was kind of basing it on this test
http://www.hotrod.com/features/1507-...ifolds-tested/
And also an engine build from someone that has built many cars for the series
My heads will flow a little better than his though
My mild road race build by Byron Koury Racing Engines
* freshened ex ASA LS1 short block with Katech rod bolts
* stock 243's with ISKY 165-A valve springs
*Comp rocker trunion upgrade
*Crane 550/550 236/246 106 LSA
* 3 stage Aviaid dry sump system
* Performer RPM intake
* Holley 80541 650 cfm carb
On superflow engine dyno made:
487 HP @ 6400
451 torque @ 3900
400 plus pds ft torque from 3200-6400
We have found previously the EFI version with LS6 intake and stock throttle body usually makes a few less HP, but a bit more torque.
should be an excellent, reliable road race motor for club racing
487 HP @ 6400
451 torque @ 3900
I decided not to use the 10an fitting on the pan for the oil inlet because I don't want to trust this pan to seal with 60-70psi of oil flowing through it, the rail isn't the flattest. I'm going to use an adapter on the rear of the block instead
What is your opinions of roller rockers vs stock rockers? I found some roller rockers that will cost about the same as the trunion upgrade. The springs are 394 rate so I figured the stock sliding wouldn't be the best
At this point I think I'm lacking a cam, lifters, an intake, timing chain, msd 6010, and probably some random stuff I forgot
Need to do some research on the timing chain
Keyway cut
Plus on pan rail
Plug in front
Oil pan
Keyway cut
Plus on pan rail
Plug in front
Oil pan
I can't really criticise on how you chose your manifold because I based my manifold choice off that test lol
I used the same way to plumb in my oil feed line, engine not going yet so I can't give feed back.
Heard about the MSD controllers being hit and miss- have you looked into the Daytona sensor controller?
Ohh nice. This is almost identical to the engine combo i used on my road race 180sx. Although i just flycut my stock pistons instead of using forged parts for now.
I used johnson slr lifters with pac springs and the trunion kit. I got a custom eps cam that ended up around the 242/248 at .05 109lsa. I can't quite remember the lift off the top of my head but its pretty much a t-rex cam.
I'm also using a holley e85 xp 650 on a vic jr with the 6010.
I only just got to the point this week where I'm wiring the whole car up, so it's still a few weeks away from first startup but i can't wait to see how your car performs!
Heads arrived, will get some better pictures this weekend. Might have a few questions on what to look for before running them
I think I'll go with the katech chain, I guess a double roller needs clearancing. I need to figure out the timing chain dampener now, the one that fits an ls1 is around 100$ and the ls2 one is 10$
What would be the pros/cons of going to a 1.8 crane lifter? I have some available to me for a really good price
I'm going to have jones racing cams grind me a custom cam once I get all my parts sorted out
Also, I bought the wrong rods, I needed .945 bushed rods and had to get h beams
Be careful with those champ pans. I have experience with them on K&N pro series motors, they always leaked and caused problems. Another issue is that pan (along with the common Moroso pan they use now) is designed for turning left, and they starve for oil if you dont add a pickup on the opposite side. This summers race at Watkins Glen - 8 motors (yes 8) were lost between practice, qualifying, and the race. All starved of oil, locked up solid, and they all blew the same rod out the same side of the block.
Do yourself a favor and get a better pan. Yes, I know you are trying to keep a budget, but a little money now will save plenty of headaches in the future. Plus you can always transfer the pan to another motor in the future.
Love the car, been following the project on corner carvers. I plan on a similar build in the future after my current projects get finished. Can't beat the cost:performance ratio, and you can't get a safer track car. You got a screaming deal on that chassis too.
Thanks, I did get a killer deal. Might not be able to transfer the pan if it throws a rod lol
Yeah The flange wasn't square at all when I first got it. I was able to get it to sit flat though. It has a little crack that I need to weld up also
All the dry sump options seem to have the pickups on one side from what I could see
I guess my options are to either add a pickup myself or have a pan custom made.
This pan was from a k&n car I believe, I hope it's not too deep and clears my cross member. I think I set the crank center line at 11-12" with the sbc. I was guessing ride height also. I think the transmission will still be the low point.
The whole no 153 tooth fly wheel thing is going to cost me a little also, I'm just going to get a whole clutch/belhousing kit with a reverse mount starter. Doesn't seem worth while to piece it together on the ls1. Going to be a pricey drivetrain between that and the transmission unfortunately
I found this, seems tempting
http://sdparts.com/i-21039308-canton...lding-req.html
http://www.aviaid.com/shopsite_sc/st...ls7-chevy.html
I went with a modified canton 12-200 pan. At the time I asked if it was necessary to have pickups on the opposite side and i was told the crank will flick the majority of the oil onto the one side anyway so it's generally not needed. How that differs with the windage tray on the ls motors still installed i'm not sure.
Since you have that pan already you could weld in some ramps and baffles with trapdoors to try and keep the oil over the pickup tubes under all conditions.
I am using the 3" deep Aviaid pan. Was told by them it will work in left and right turns because of the dropped sump. You may want to check them out.
I would at least try to put an extra pickup in the pan. To those familiar with dry sumps but not these pans, they are not the typical aviad or Dailey systems. The moroso/champ pans barely have any baffling or windage control. It can definitely be a capable system if setup properly. I would even look at adding an Improved Racing crank scraper. Cheap and effective - every little bit of oil control helps especially with the speeds this car will be doing on track.
While costly, the whole reverse mount starter/button flywheel setup is worth the money. Clears up so much space to work on the engine, and you will love a tiny clutch on track. Look for a used k&n setup ready to bolt up to an LS motor.
NASCAR mandates the pan in a spec engine package. They don't care if you lose an engine, it's more money in their pocket when you have to spend 30k on a new one. We would love to spend the extra money up front and run a Dailey system so we get better life from the engines. NASCAR tells us to get bent.
Your crank height should be ok, I have to check but I think our new chassis is 12" per the rules. It's most likely an old k&n pan, we used to run those before the current moroso, which is basically the same pan.
