Msd 6010 trouble
My motor will start once in awhile but usually not. Its high compression stroker. I've tried the box on another similar motor and it is better. Both seem to have to crank awhile before they lite. Last year it started quick but it was lower compression motor. I've tried an extra battery to only run ign while cranking. I hate to have to buy another brand ign but I'm stumped.
This one cranks a lot faster than my other one. Both are strokers, in jet boats. This is the one with turbo. I just put a new block in it after breaking my other block a month ago.
Hook a laptop up to the unit while cranking. See what the cranking RPM is. If it is zero than the unit is having issues reading the crank sensor.
What idle timing are you running? Backing off on that helps. You can just set the 500 RPM value to something stupid low and the 1000 RPM to what you want when it is running.
Also are you running a MAP sensor and if not did you zero out the map curve? That will really make it hard to start. That mistake on the 6010 cuts in something like 22 degrees of advance all the time.
Thanks for reply. Cranking rpm is 185. Timing is barely above zero . map timing is adding some. Not much tho. I'm going to try reducing plug gap next. Its already down from 35 to 25. Going to try 20 and maybe 15. It lites my other motor which is same c.i. and compr. But it has more overlap in the cam which probably reduces cranking compr.
No. Ordered new cranksensor but don't have it yet. I doubt its the problem but I'm willing to try it. Next I'll swap the box back to my other boat, then maybe put that box in this one or swap harnesses.
Thanks. I can't figure it out. I put the box on my other boat and it fires right up even tho its nearly identical motor and a weaker battery. It seems like it must be in the wiring harness but I've checked every wire. New crank sensor and can sensor didn't help. Haven't tried coils but how could 8 coils all fail at once?
I swapped the wiring harness over to my other boat. Fires right up. Seems like it has to be coils or maybe bad new crank sensor. Learned one thing. It runs without connecting can sensor.on laptop It doesn't show cranking rpm but neither does the one that runs.
It might be the reluctor wheel. Many years back people with a certain brand of aftermarket crank couldn't get the MSD box to work. MSD actually came up with a firmware fix that corrected most of the problem. But every now and again I still see people complain about a motor that just does not work with the MSD unit.
You might try contacting MSD directly. They have been pretty good about reflashing people's boxes.
Got it running today. I put in my old megasquirt box and harness from when I was trying to run Efi. It fires ign just fine. Lots of extra wires that I don't need. Now I have to figure out how to change the timing on it.
Got my timing set with ms3. Now I have an extra Msd with harness. It works fine on my other boat. Don't know why it wouldn't fire my turbo boat. It did last year. Anybody needs one, I'd sell it. Or advise to get Daytona sensor box instead.
