Intake suggestion
Intake suggestion
stock LQ4 with 243 heads, LS9 head gaskets, Tick torquemax stage 2 cam, oil pump and trunion upgrades.
3000# car, TH350, ATI tight nitrous convertor (stalled about 4K behind the old small block), 4:10 rear and 28" tire.
I have a few things left to get: 1 7/8" headers and more than likely a Daytona Sensors box. I have a couple of carbs to try including a 950 ProSystems.
What would the recommended intake be?
Restricted User
In all of the builds I've done, N/A with a fuel injection cam, the dual plane has outperformed the Holley single plane and the Vic Jr every single time.
As long as he doesn't use a junk plate and it has a sprayer for each runner, distribution will be fine. It won't escape from one runner to another.
Most guys are running a "junk" plate and not a fogger to start with. Especially budget set-ups.
I'm on board with the guys saying single plane regardless. A dual plane may be a better option N/A for low end torque, but with nitrous in the future, I would just do it once and be done with it.
Restricted User
Restricted User
Old School Heavy
Did you get the LS2 Stage 2 cam(231/235) or the LS1 Stage 2 (226/234) cam? My car went 11.04@121 with a cam identical to the LS1 Stage 2 cam back when I had a SBE 6 liter. It is a nice working camshaft.
Old School Heavy
The main difference is the LS2 version has a later intake valve close, so the power curve will be moved up versus the LS1 version. You could advance it a couple degrees if you are comfortable with that procedure and check the intake valve clearance just to be safe if you do.
Intake Manifold/Firing Order
The use of a "Dual Plane" intake "H" on an engine with the GM 18726543 firing order may not be the best choice.
The intake manifold, if designed well, will measure a MAP of 106+ KPA on a 101 KPA BARO day.
This supercharged effect is a result of manifold design/engine firing order.
When the GM firing order of 18436572 is used, the "H" Dual Plane will work better.
My data is from MAP measurement at engine "song".
Lance
Lance
here is my experience. I've had the truck manifold, ls6 manifold, fast 90mm, ported fast 90mm and a vic jr. I've sprayed every one of these intakes too.
vic jr gave snappier throttle response, better top end, better track times, better nitrous distribution. just make sure to have a cam cut that's intended for a single plane intake. you can keep your KPA numbers. a time slip tells the actual story.
I've seen engines touch 102 kpa before...never seen 106+. not saying it's impossible as i'm not a professional tuner. just haven't seen it with all the intakes above installed on motors anywhere between 5.3 and 6.7. I find the "supercharging" effect to sound bogus. the motor is sucking air. there is no supercharging effect without something forcing air down the motor's throat.
I would recommend the single plane even with the smallest intended shot of nitrous through a plate.
