Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Guys with short belts...
Old 03-26-2017, 08:22 AM
Doug G's Avatar
Default Guys with short belts...
How is your belt ran ?
V or < or > or some other way ?
Old 03-26-2017, 11:32 AM
Pop N Wood's Avatar
Old 03-26-2017, 04:30 PM
Doug G's Avatar
Thanks Pop, my alt is higher on the head. I was thinking I may need more wrap on the WP ?
Old 03-27-2017, 04:18 AM
Pop N Wood's Avatar
I wondered that myself, but probably the most common alternator only set up has the alternator in the low F body position so even less wrap on both WP and crank pulley. I've been running like this for 8 years or so, no charging or cooling issues and I've never thrown a belt.
Since no one had issues I figured this set up would be OK. Some guys add a tensioner where the idle pulley was, but doesn't seem necessary
If you get the alternator above the head you will be golden.
Old 03-27-2017, 04:30 AM
Doug G's Avatar
I must have something weird going on...only like to throw belts in the 7500ish range.
I don't know....going to recheck and address things.
Old 03-27-2017, 06:41 AM
TTur1996's Avatar
Here ya go Doug. Get rid of the hula hoop. Put on an electric water pump. Then you can let that bad boy spin away. And all your troubles will simply go away. You won't be throwing this little belt off. The best part of the electric water pump is being able to shut the motor off and still cool everything off very fast. Not to mention you don't have to worry about aeration from cavitation at high rpm causing poor cooling when you really need it.
Old 03-27-2017, 07:12 PM
Doug G's Avatar
TT, that may be an option one day....but not in the cards right now.
I found something off. used a straight edge and checked crank pulley to alt....good. Checked crank to tensioner....good.
Alt to tensioner....no good.
Moved some stuff around, shim here, shim there.....all less than .100" out now. Ssssooo, time will tell.
Old 07-31-2017, 04:42 PM
nightrider123's Avatar
Kinda hard to see
Attached Thumbnails Guys with short belts...-img_1697.jpg   Guys with short belts...-img_1696.jpg
Old 07-31-2017, 07:20 PM
Doug G's Avatar
After fighting an issue and grasping at straws....went electric WP.
Still need to figure out Alt mount, pretty sure I have something now but hunny-dos and 7 day work week kicking my ***
Old 07-31-2017, 07:30 PM
Nice! I been kicking around going electric but im planing to sell and don't want to put to anymore money in lol
Old 08-01-2017, 04:49 PM
fast89stang's Avatar
Doug, have you checked your crank end play? May not be a issue, but seems weird you were throwing belts.
Old 08-01-2017, 05:53 PM
Doug G's Avatar
I've tried my big pry bar....nothing moved
Old 08-02-2017, 06:51 AM
Bowtiedford's Avatar
mine is set up the same way, never thrown a belt. 7400 rpm
I did cut off the top ear on the alt mount.
Old 08-05-2017, 06:13 PM
Doug G's Avatar
Went from..........
by https://www.flickr.com/photos/123907483@N04/, on Flickr
to.......still awaiting belt (be here Saturday) and finish alt adjuster. BUT, looks better already
Old 08-05-2017, 06:18 PM
Doug G's Avatar
double posted pics ??????WTH ?????
Old 08-06-2017, 02:08 PM
Doug G's Avatar
OK, all done except the belt tensioner.
I'll take care of it at work slotting the holes on the end-mill.
Wish I knew how to TIG
Old 08-11-2017, 05:07 PM
Doug G's Avatar
All done last weekend. Finally tested (weather sucked last week) BUT.... let her idle in the 88* humid air we have right now.
45 minutes at idle, only went to 145*-150*, has no T-stat, and only 1 fan running
Never rev'd over 3-4K, but belt looked good.
Old 08-14-2017, 04:50 PM
Old School Heavy
speedtigger's Avatar
When I saw the title of this thread, I thought maybe it was a support group.
Old 08-14-2017, 05:39 PM
Doug G's Avatar
Ha !............well, sortta I guess.
Keeping me sane and working in right direction
Old 08-14-2017, 06:59 PM
zzracer's Avatar
BMR makes an alternator bracket that is slotted so you can adjust belt tension. I am running one with my electric wp in my Camaro.
Quick Reply: Guys with short belts...
