Crate engine timing
The ASA cam is a step over stock and on a 110 LSA....I'm thinking it would be OK at 30-35, but better to start very conservative and go from there to see what YOURS likes
My main reason for posting is that I tried (and failed) to find out how GMPP dyno'd the engine performance reported in their literature. Best I could come up with is this from another site.
"I used to work at SPO headquarters and the GMPP engineer on the LS3 crate engine program ran ALL of them at 27*, that was the sweet spot."
Here is that whole business
https://www.hptuners.com/forum/showt...6-2-LS3-timing
I talked to a Tuner that I HIGHLY RESPECT, and has many LS swaps under his belt. He said at idle start at about 18*. Start ramping up to about 25* by 4000 rpm. Go a couple more degrees by 6500. Also that not many set-ups will see any gains above 30* . So that 27* that engineer spoke of is right on track with what my guy said. And remember this is strictly for a NA set-up. Any forced induction or nitrous will greatly lessen the amount of advance that is need to be safe.
GOOD LUCK
