2-step launch ?
When was the last time you checked that you are getting full throttle? A lot of guys forget to check it. Brackets and cables moving just a hair over time can be an 1/8 or more throttle blade movement.
foot braking, you’ll need to try off idle, then pre loaded. Then start launching at different two step setting tool you find the seeet spot. All cars are different.
