Black Smoke At Full Throttle
Hi, i currently own a 1999 Camaro SS with 82k miles on it. The other day i was driving with my cousin he had his mustang and was driving behind me, so i decided to puncht the gas. He said that a black cloud of smoke came out when i did it and it smelled really bad, kind of like gas or oil im not sure. What could this be coming from? Remember it only does the smoke at high revs.
Thanks for the help
Thanks for the help
ive seen mini vans do this too.. alot of cars do it, obviously some more than others. some u cant even see.. and yes it pushes as much as possible but not to the point were it will starve for air.. and its called open loop, goes back to closed loop when going back to normal driving operation and starts reading O2 sensors again..... my friends new mustang (at the time it was new) would do this all the time when i would try to pass him pretty fast and he would just gun it.... I work with cars all day and i know what im telling u.. if it was not at WOT then yes it would need a tune... this is mostly common on v8's though
so just because some stupid ford does it that means every car does? lol
no car is supposed to do this. NONE. not even deisels. black smoke is a sign of unburnt fuel, lost horsepower, reduced efficiency and it is bad for everything it touches on its way out. if this is happening to something that is stock it means you have an issue somewhere whether its with timing or fuel delivery. it may be hard to chase down but i am guessing it has lit of an ses light. when this happens to modded vehicles it is the sign of a bad tune.
unburnt fuel can do a number of things, it may harm your cats, and your o2 sensors. it can even make your o2's read this as a lean condition since the fuel is not burnt. making the condition even worse. in extreme conditions it can wash your cylinders down and even contaminate your oil. it will spike your cylinder pressure leading to detonation. and despite popular belief it can make your engine run hotter since the fuel burns slower. this kind of rich condition is bad in every way not to mention it makes the back of your car look like crap.
so in short, this is not normal in ANY way, shape or fashion. unless you drive a big unlimited John Deere Tractor at the tractor pulls.
