Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
LS1 '69 Camaro Swap
Old 01-16-2011, 10:21 PM
CamaroAJ's Avatar
wow, i take for granted all the room i have setting my engine back. 4th picture https://ls1tech.com/forums/chevrolet...aro-build.html
Old 01-22-2011, 10:24 PM
i1aroc's Avatar
yeah, wish I had just that little extra. nice build
Old 01-22-2011, 10:33 PM
i1aroc's Avatar
Got something in the mail the other day. weighed a ton.
installed with the nascar driveshaft and torque arm in position
went with 4 piston in the back an 6 piston in the front
pic of old faithfull
pic of the new
Old 01-26-2011, 04:19 PM
tsnow678's Avatar
I see your making fast progress. Looks great! I have a couple of questions for you if you dont mind. Where did you get the elbow coming off of the throttle body? Who made it? I reread your thread and see where you put in a 4L60E but you have a reservoir on the firewall that looks like it goes to a clutch master. Is that from the old setup? The Wilwood master for the brakes, are you using the stock proportioning valve in conjuction with the adjustable one?
Sorry for all of the questions I am in the middle of finishing everything up so I can set the engine in for a final time I hope.
Old 01-26-2011, 07:15 PM
69ls6's Avatar
was your motor mount plate in factory or 1 inch back postion..doing the same with ls6,6 speed.car is painted and almost ready for engine and trans..may post some pics later
Old 01-26-2011, 07:41 PM
i1aroc's Avatar
Ask away, no worries. I originally wanted to go with a 4l60e, but came across a package deal with a T56 six speed so I jumped on it. The elbow off the throttle body came with the engine package, sorry I couldn't be more helpfull on that one. Adjustable Wilwood only being used.
Good stuff on your build, keep up the great work.
Old 01-26-2011, 07:47 PM
i1aroc's Avatar
Motor mount plates are in the factory position. I probably would have liked to go 1 inch back, however, it is pretty tight back there as it is, so I shouldn't complain I guess. The elbow I purchased up front from PI had to be cut just so I could clear the fans.
Old 01-26-2011, 08:03 PM
tsnow678's Avatar
What did you use for the clutch master? Brand, part number, piston size and stroke if you have them. Or did you use the factory style? Thanks
Old 01-26-2011, 08:04 PM
CamaroAJ's Avatar
http://intakehoses.com/Merchant2/mer...gory_Code=MIE0
Old 01-26-2011, 08:06 PM
tsnow678's Avatar
Thanks for the link! Just what I was looking for!!!
Old 01-26-2011, 08:14 PM
MillerTime85's Avatar
Old 01-28-2011, 09:57 AM
  #32
armkneez8's Avatar
Very Nice work. This is my goal: a 69' Camaro with a LSX powertrain. Keep the pics coming.
Old 02-03-2011, 04:36 PM
  #33
whytry's Avatar
you driving it yet? I'm really interested in the suspension as well as your thoughts on overall install of both motor and rear torque arm....
I'm just starting to figure out my LS setup in my 68....
Old 02-03-2011, 09:54 PM
  #34
i1aroc's Avatar
We've had a bit of snow up here, so won't be driving the 69 for a couple of months yet. I am also waiting on my billet rims, gauges, and engine accessories to arrive. Will post some pics and probably a video showing what the suspension can do once spring arrives. If it behaves anything like my buddies, who did the same work, then this car will stay planted in most situations.
Old 02-05-2011, 08:37 AM
  #35
i1aroc's Avatar
Got cluster ready to accept the new gauges coming in next week. The right side required an approx. 5/8" spacer so the gauge will sit flush like the left side.
Old 02-05-2011, 03:16 PM
  #36
Indyjc's Avatar
You have a radio delete plate? Is it original or repo, if it's orig. it's might be worth a mint. Very nice car. My first 69 was hugger orange.
Old 02-05-2011, 08:38 PM
  #37
i1aroc's Avatar
It is a reproduction plate I picked up a while ago unfortunately. I wish it was original.
I was originally looking to buy a lemans blue first gen, but this hugger one came up and the sale went very smooth. Took some getting used to, but pretty happy with the color, thanks for the compliment.
Old 02-13-2011, 04:02 PM
  #38
i1aroc's Avatar
Coming together now, gauges are in. American muscle units used and match the lecarra steering wheel nicely. kind of glow like a 2010 camaro with less intensity which is fine by me. please don't mind the mess. nice to see that six speed shifter in there. just waiting on the billet rims and nittos to arrive. fired up the camaro and it held perfect idle first time. not sure what exhaust to go with yet.
Old 02-13-2011, 05:41 PM
  #39
tsnow678's Avatar
Looks great! I like the gauges. You say they are American Muscle? Who makes them?
Old 02-13-2011, 06:34 PM
  #40
i1aroc's Avatar
Smile
Thanks man, they are from autometer. I picked up the 3 3/8” 160mph Electronic Programmable Speedometer, and 8,000 RPM Tachometer. Fit right in after cutting away at some plastic from the edge of the cluster and applying a spacer for the tach side.
Auto Meter announced the introduction of their new American Muscle series gauges. The latest in designer street performance instruments, American Muscle instruments feature advanced hybrid dial technology combining Auto Meter’s signature white Hi-Def LED illumination and glowing red pointers for maximum readability with spun aluminum dials featuring embossed details for classic good looks. Finished with Chrome Super Bezels, American Muscle instruments are available in compact 2 1/16” size for fuel level, water temp, oil press, and battery voltage measurements, with 3 3/8” 160mph Electronic Programmable Speedometer, and 8,000 RPM Tachometer. Five gauge kit box includes speedo, fuel level, oil press, water temp, and volt gauges with required sending units for installation on most domestic muscle, street rod, custom, and truck applications.
Quick Reply: LS1 '69 Camaro Swap
