Need help picking a cam.
I have a 02 camaro with a ls1 M6. Engine is stock but id like to upgrade the cam. I dont want a racecar or it to sound like one. I just want a bit more power & a good sound. Any advise?
Flowtech Streetsweeper HT. Its a custom grind 228/232 that makes a ton of power and Im sure in your car itll be right around 400hp. Not too many people run this cam on here since Flowtech isnt a sponsor, but Ed Curtis who designed it knows what he is doing and has a very proven track record for making power.
Go with a Comp Cams 3722/3724 with a 114 LSA. Great power, not an overwhelming sound and great drivability.
Model No 54-000-11
Grind number 3722R / 3724R HR114+
Cam Spec INT EXH
ADV DUR 273 277
DUR@ .050 224 228 LOBE SEP: 114.0
Valve lift .581 .588
Also known as a 6016 on AFR site.
Model No 54-000-11
Cam Spec INT EXH
ADV DUR 273 277
any upgraded cam needs better springs. if your looking for great drivability w good power the tr224 but that wont get you to 400rwhp. the tr228 or comp 228/230 w 112 lsa is about the max i'd go if drivability was important. just my one cent. plenty of choices , call a few sponsors tellem what you want. cheers!
