Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
Door not closing properly- 2000 Camaro
Old 08-22-2015, 06:30 PM
DomsLT1's Avatar
Default Door not closing properly- 2000 Camaro
Hello all, the driver door on my 2000 SS is not closing right. You have to really slam it in order for it too close. I thought it was just the hinges but the triangle looking seal on the door connected to the sideview mirror hits the weatherstripping before the door can even make contact. It shuts almost perfectly with the window down but with it up it hits before the door can lock close. Is there anyway to adjust the seal?? Or is something else causing this.
Old 08-22-2015, 06:47 PM
Mappinsj's Avatar
Door hinge bent, look at that triangle it's being bent on the top
Look at the angle of the door and fender
Old 08-22-2015, 11:16 PM
DomsLT1's Avatar
So you think it could still be the door hinge? Will check first thing tomorrow
Old 08-23-2015, 06:31 AM
Mappinsj's Avatar
Yes that door has something bent in the hinge area
Quick Reply: Door not closing properly- 2000 Camaro
