Shark Gray 2000 SS build
The following users liked this post:
Gripenfelter (08-29-2020)
#382
I watched that the other day dude. Pretty cool runs! Love your ride!
LaBLKv6Z (10-09-2020)
#387
you run yours again or got any idea what it’s trapping now? It ought to be over 130ish
#388
yea I should be about to take him with the new setup once it’s lined out. I’ve had issues getting my boost controller settings right. It’s got a lot of settings that make it act weird. I was having some surging issues a few weeks ago. I’m still not 100% certain it’s fixed yet.
#389
Sucking GAS and hauling ***!
LaBLKv6Z (09-02-2020)
#391
Thanks, yes the rear tires do rub on hard bumps. No damage to the tires or fenders but I do notice rubber on the tops of the rolled lips as well as shiny spots on the shoulder of the rear tires.
#392
Here’s a couple runs with a 19’ Mustang GT A10, full bolt on/ported intake/e85.
https://m.youtube.com/watch?feature=share&v=igF-l48c8pA
#394
Looks like a winner to me.
LaBLKv6Z (10-19-2020)
#397
Disassembling the G-Plus 92mm TB for modding.
Marked for the half shaft delete.
Polished the blade, it had rough cuts in it.
Opened up the IAC ports, they were definitely on the small side.
Reassembled.
fucter (01-19-2021)
#399
So I decided to hit my warm start issue until I found the solution and got it. It ended up being the Crank fueling, leaned it out in the trouble temp areas and good to go. Will be making a few passes at the track tonight while the weather is fair.
AINT SKEERED (11-06-2020)
