Unusual Question
Unusual Question
What is the correct undercarriage paint code for my 2002 SS ?
Exterior color is white and the undercarriage appears to be a light grey.
For all I know there were different colors depending on the exterior ?
It would be great to have an exact match as to blend in with the original as needed and not have to paint the complete undercarriage.
Rattle can would be a blessing due to limited lift.
Yes, I know my photo is my previous Red SS. That will be changed as soon as the White one is presentable for viewing !
I could be wrong but I always assumed its the same paint on the rest of the car just without the clear coat, that is what it looks like on mine at least but im not a paint/body work expert.
I know some of the paint codes are listed on the door sticker. I'm not the one to ask as to which one it is, but I have a few friends that do bodywork for a living.
I agree that whatever the color of the car is what is on the bottom without clear coat, mine is also this way.
LS1Tech Administrator
Received 1,529 Likes
The color appears different because it was sprayed thin and without a clear coat. The primer visibly bleeds through the thin outer layer and that's why it doesn't look quite the same as the engine bay (which is also the same color code, minus the clear coat, but is applied a bit thicker.) If you look under a black example, they sometimes appear almost green, etc.
This is the underside of our 00 TA that is white (excuse the dirtiness please, just finished installing all the suspension and haven't cleaned yet).
Also, on my 2002 Camaro 35th LE the underside is red. So i'm leaning with what the guy above said and the primer seeps through.
I do know the paint in our engine bays are believe it or not are different from the paint on the outside and any paint underneath I believe matches the engine bay paint. Reason I know that is I have a buddy who does some amazing engine bay work on 4th gens to make them look just as nice as the outside of the car. When he purchased the paint for his SOM Trans Am the guy at the paint place informed him of this and told him it was actually a different paint code and explained why it was different. So he ended up purchasing the matching engine bay paint and clear coating it. I would imagine that would be the same as the engine bay paint on the parts that are painted to the color of the car. Ill have to touch base with him and get more details. As for the grey im not sure.
On the other hand, my daily driver '02 Pewter car wasn't quite as perfect of a match between the engine bay and exterior paint (exterior touch-up paint appeared darker). Engine bays tend to get discolored/faded on daily drivers I think, I suppose from general engine/road grime and heat?
Now my engine bay looks real white and matches the exterior like a exact match. The underbelly paint, on my 2002, has a definite satin finish. Not primer rough but a smooth overcoat on whatever the real color is.
Maybe it's the reflection of my 73 year old blue eyes and white hair.
I wasn't saying the underside was white, I meant this is the underside of our white TA. It's definitely not the same shade as the exterior or the engine bay which makes me believe it either wasn't sprayed heavily from factory or it's the primer showing through.
I would agree that mine is a rendition of the Arctic White exterior sprayed on much thinner almost in a primer formula. Plus colors can be deceiving under different lighting conditions. Once I get everything all cleaned up I'll play around with some rattle can choices to see if any can closely match up. Not intended as a show piece but just neat, clean and tidy without the battle scars popping out at you. Hey, a clean car runs better !
