Special model camaro? F1?
Anyone ever heard of this model?
Or did he pull the ultimate fbody hoax ever?
https://inlandempire.craigslist.org/...756806812.html
Wonder if that was some kind of dealer based add on.
LS1Tech Administrator
Received 1,493 Likes
This car is absolutely not a factory creation, but I wouldn't exactly call it a hoax either. This F1 "package" was available as a dealer add-on and/or owner add-on parts through GMPP for some of the 4th gen years (dates back further than just the LS1 cars).
No clue if the dealer did this package or the guy just ordered all the parts himself, but some items certainly wouldn't have been part of the package in '99 - such as the Blackwing lid (which hadn't even been released by SLP for Firehawk or SS yet in 1999, therefore didn't exist when this car was originally delivered and must've been added later), and the STB which is clearly aftermarket (as that particular version was never an SLP or GM piece). Interestingly, I see that he still has the AIR tube hooked up to that Blackwing lid - but what does it attach to? The AIR system didn't connect to the air box on '98-'99 cars, so unless he's using a '00-'02 AIR system it must run to nothing.
Also, not sure what the owner means about a "set of service manuals on disc that were sent by GM to the owners of 1999 Camaros". I also bought a brand new Camaro Z28 in 1999, and GM never sent me any such manuals. Perhaps this came along with some of the GMPP/F1 items.
It is a GM designed kit with the front and rear lower facia extensions and the rocker panel extensions and the stickers....Was available through GM dealerships (GMPP) beginning in 1993 as stated above...Could be either dealer installed or by the car owner....Was NOT a factory RPO and not factory installed ..If I remember correctly it cost about 1400.00 dollars from GM... Then had to be painted to the correct color...Was also installed with double sided tape...No drilled holes..Lasted about 5 or so years before the parts started falling off...at least in my part of the country...Same kit was also available for the Firebird..Was called the Firebird GT...Had GT stickers instead of F1 stickers...Would not fit the Trans Am...(different front and rear facias)..Strictly a cosmetic kit.. No performance enhancement at all...
As far as the set of "Service Manuals on Disc" Anyone could buy one through the parts dept at any GM dealership....But they were and are extremely... Break it off in you type.. Expensive.....and did not come with any GM car...
As for the Special Order claim...
Only 1LE cars 1988 to 1999 were the truly Special Order cars..(Was the Only way to acquire one new) Even then was supposed (didn't always happen) to verify your racing credentials before they would order it.....
I just took the "special order" claim to mean that the owner ordered this car rather than buying dealer inventory off the lot. But I agree - there's nothing about this car, from the factory, which makes it truly special. Only the add-ons and modifications that were done by the dealer/owner make it particularly unique.
Ungrounded Moderator
I got the CD Service Manual set off ebay years ago for only about $50. It's a six disc set which I still use regularly for answering questions here. It covers most GM models between 1997 and 2002. Unfortunately, it's old enough that is doesn't work with any version of Windows after XP so I have to run a virtual Windows XP machine to use it.
I would check the install and paint quality and color match very carefully on a car with one of those kits
Rant follows...[soapbox/ on]
Some of the local dealers in the Gastonia /Charlotte area of North Carolina got very aggressive with these horrible kits on new 02 Camaro's. They would slap them on base model v6 cars, Z28's and SS cars left and right. Lot of the install work was sloppy with mismatched paint. Usually the white cars matched OK, the black would match but show blemishes a lot of the time but pewter color cars seemed to suffered the most with bad paint match.
I'm sure a few dealers did a quality install. Sonny Hancock Chevrolet in Gastonia NC definitely did some of the worse. I doubt their kits held up well for 5 years. Probably part of the business practices that led to them going out of business as a GM dealer in 2009 and eventually closing completely.
Some added + $1800 to $1900 for the appearance package.
One salesman got upset when I asked, "Why should we (wife & I) pay an extra $1,800 for an ugly, badly installed kit with mismatched pewter paint?"
[soapbox / off]
Wife ended up with a red 02 Z28 without that tacky body kit.
[soapbox / off]
^ As mentioned above, the body kit on the car linked by the OP was a factory option under RPO Y3F (SAP, Sport Appearance Package). Perhaps the dealer installed GMPP "F1" package used the same body kit but, in this case, it's Y3F content and is listed on the original window sticker (therefore factory installed, not dealer work). From the factory, this kit was not available on SS cars or cars in certain colors (the GM order form excluded one or two colors for RPO Y3F, but I don't remember off-hand what those colors were, I'd have to look it up).
