F1 Camaro?
Was the F1 an actual camaro that was made in limited numbers? I thought it was just an appearance package that could be added. But, my friend swears he knows a guy with an "F1" camaro-1994 i think- thats supposed to be one out of like 400 made, and its supposed to have alot more power & racing suspension from the factory. Whats the true story?
F1 Camaro info... apparently only 980 ever made: http://www-personal.umich.edu/~hopkinsm/camaro.html
http://www.f-body.org/faq/4/4_1.htm#ch4_1l / http://www.ws6.com/faq/4_1.htm#ch4_1l
http://64.233.179.104/search?q=cache...t%26t%3D516862
F1 Camaro photos: http://imageevent.com/ls1z28/f1camaro
Edit: More photos: http://www.geocities.com/jz2822/F1.htm
Q: What's included in the F1-Camaro/Firebird-GT package?
A: This is a package available through most dealerships. It offers a variety of performance and cosmetic parts from the GM Performance Group. The following is a list of the parts for the F1-Camaro (and for the Firebird-GT) and can be ordered for your Z28 or Formula through your dealership:
Part No. Description
12363906 32mm front stab. bar, bushings, link kit, and track bar
12364002 17"x9"x50mm ZR-1 style wheels with P275/40ZR-17 Comp T/A tires
12363998 16"x8"x66mm ZR-1 style wheels with P245/50ZR-16 Comp T/A tires
12363902 6-speed Hurst shifter (leather wrapped shift ****)
12363925 cat-back performance exhaust (dual single-side outlet)
12363940 3 piece rear spoiler (primed)
12363915 4 piece ground effects package (primed)
12363978 cold air induction package (1993, for use with MAP)
12363979 cold air induction package (1994 and up, for use with MAF)
12363910 F1 Specialty Vehicle Package - everything above (1993)
12363911 F1 Specialty Vehicle Package - everything above (1994 and up)
123638xx coup floor mats (xx is 94-graphite, 95-gray, 96-beige, 97-neutral)
123638xx conv floor mats (xx is 98-graphite, 99-gray, 00-beige, 01-neutral)
It's a kit from GM that is no longer available. It comes with suspension ,exhaust, intake and body upgrades.The kit professionally installed and painted ran about $7,000.00. It's my understanding that GM sold less than 1,000 of these kits.
The F-1 kit was sold through the dealer parts department. It was installed on a few by the dealers to aid in the sale of the car. But I doubt your car has it,unless you put it on the car yourself. The kit is no longer available from GM.
You could order the GFX kit from GMMP and install it yourself or have the dealer do it. I think they had an intake and exhaust opton for the V6's too. I only ever knew of the girl I worked with having a dealer installed package. I haven't seen another one around.
Found a few more photos of someone else's car (added the link to my earlier post - http://www.geocities.com/jz2822/F1.htm )... looks like regular lights on here, so I'm pretty sure the owner of the 'ls1z28' one changed them
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
F1's just had regular lights. A girl I used to work with about 8 years ago got a 97 30th anniversary Z28 with the F1 package on it from the dealer. I wish I knew what happened to it as I didn't realize how rare the package was. It looked really sharp on the white car with the orange stripes. The only thing it was missing that I would have wanted was the houndstooth interior and a 6 speed.
