Chevrolet Camaro 1967-2002 The forum for diehard Camaro fans
speed limiter?
Old Jun 19, 2006 | 01:41 AM
SLVR_99-Z's Avatar
Default speed limiter?
i did a search but didn't find the info i am looking for. what is the speed limiter set at on a 1999 Z28 M6? i heard 160 but i want to be sure and i don't have a place to test it out right now. thank you.
Old Jun 19, 2006 | 04:50 AM
seawolf18's Avatar
i think it is 162 if it came with z-rated tires from the factory.
Old Jun 19, 2006 | 05:02 AM
1fastTransAm's Avatar
From: Chitown-Jax NC-Jax FL-Honolulu-OKC, OK-NOW New Orleans Area
our cars are not speed limited but rev limited from what I have read. I did 172 on mine till it was winding out in 6th. food for thought
Old Jun 19, 2006 | 08:59 AM
12secSS's Avatar
LS1 F-bodies have a rev limiter set to 6100 rpms, but that is seperate from the speed limter based on the rating ot the tires. Z-rated is limited in the ECM at 160 MPH, which is the highest MPH allowed with factory programming. I have changed these setting on my vehicles with HPTuners.
Old Jun 19, 2006 | 11:18 AM
TLUZLS1's Avatar
How do you know if your car came from the factory with z-rated tires? Is there a code on the door sticker? And if it didnt then what would the speed limiter be?
Old Jun 19, 2006 | 02:43 PM
12secSS's Avatar
I know because my window sticker says it, I am the original owner of my car. If you are not, then you should be able to verify it on the door sticker (not sure though). If the vehicle does not have Z-Rated tires, it will have a 115-120 limiter. I have yet to see a non-Z-Rated car yet in my tuning ventures. I do know that trucks are limited to 98 MPH.
Old Jun 19, 2006 | 04:41 PM
rtr2001ss's Avatar
I think most of them are governed to 158. Thats about where my buddies Z tapped out at. I don't know what mine was, I had it programmed out before I ever broke 150.
And my truck stops at 100, so did my 2000 Z71 I had before. Stock GTP was 126 , till I replaced the PCM .
Old Jun 19, 2006 | 07:42 PM
rippenhard's Avatar
It was to my knowledge that ls1 f-body cars rev limiter are set to 6250 and the governor are set for around 158.
You guys should come to germany. Its nothing to see mercedes, audi, and bmw doing 250 kilometers on the autobahn. By the way thats right around 150mph. I know I do it all the time in rental cars.
Old Jun 23, 2006 | 09:34 AM
s1ck s0n's Avatar
i always heard it was set at 168.
Old Jun 23, 2006 | 09:49 AM
NVR KNO's Avatar
well i buried the speedo in my car and hit the rev limiter in 5th gear. i still felt the car pulling when the speedo was buried, so i know i went passed 170mph.
