Fox manual trans options?
Old 02-12-2009, 10:05 AM
jleews6's Avatar
Default Fox manual trans options?
Just wondering if anyone has used either a T56 or Tremac 5 speed in there swap. Is there a way to use the cable operated clutch with the T56 and is there a bell to use the Tremac TKO with the LS motor?
Thanks.
Old 02-12-2009, 11:19 AM
lt4malibu's Avatar
T56 you need TurboCoupe pedals, someone also used a TKO600 with a cable-operated clutch but i forget who
Old 02-12-2009, 03:45 PM
serpentnoir's Avatar
Default Tko
Quick Time has a bell housing to specifically mate a "Ford" Tremec TKO/toploader to the LS motor. I think Mcleod also makes one. Someone here mentionned Lakewood makes a housing to mate a toploader to a chevy big block which is supposed to work on the LS also. All speculation.
Old 02-12-2009, 05:17 PM
Qwiknotch's Avatar
Quicktime does have one and so does Lakewood.
Quicktime Part number 6036,
Chevy LS-1 Bellhousing/Richmond Style Transmission - NEW!
Height = 6.290
Trans. Bore Ø = 4.685
Engine = Chevy LS-1, LS-2, LS-3, LS-6, LS-7, LS-9
Trans. = Richmond, Saginaw, Muncie, Bert, Brinn, Chevy TKO 500-600
Clutch Ø = 11"
Flywheel = 168 tooth or 153 tooth
Weight = 22#
Stock Shifter fork & throwout bearing
Passed ALL SFI testing
Pivot ball, full engine plate and grade 8 bolts included
Quicktime #6037
LS-1 Bellhousing to Ford TKO 500-600/TR3550/T5 Mustang Transmission - NEW!
Height = 6.925
Trans. Bore Ø = Universal 4.850/4.910
Trans. = Ford TKO 500-600, TR3550, T5 Mustang
Clutch Ø = 11"
Weight = 22#
Full engine plate, trani ball and grade 8 bolts included
The Lakewood one is part number - 15005 for a tremec/ls1 standard clutch (no hydraulic)
Old 02-12-2009, 05:44 PM
rao
rao's Avatar
Does the conversion bellhousing for the ford version of the T-56 put the engine in the same place? That would make things a lot easier for a fox body swap.
Old 02-12-2009, 08:52 PM
Qwiknotch's Avatar
The bellhousing has nothing to do with engine placement, that has to do with transmission placement.
Old 02-12-2009, 09:03 PM
jleews6's Avatar
Thanks for all the replys. The TKO's can be bought cheap used and the cable operated clutch is real easy to use. This is good news.
Thanks
Old 02-12-2009, 09:23 PM
Bayou_Flyer's Avatar
SOM68SS did this on his 4-eyed notch with carb'd LS1.
http://www.mylrs.com/blogs/lrs/archi...ng-part-1.aspx
I like the idea of the T56 but would settle for a strong 5spd if it'd simplify the conversion process somewhat.
Old 02-13-2009, 01:53 AM
Slow5.0.'s Avatar
Since when is a tko cheap? I sold mine for 1500 thats more then i paid for my t56.
You also can modify the mustang clutch pedal to use hydrolics.
Old 02-13-2009, 05:50 AM
rao
rao's Avatar
Last time I checked the engine was connected to the transmission
If the overall length of the transmission from the mount to the face of the bellhousing is than an LS, the engine will be in a different position.
Old 02-13-2009, 07:20 AM
lt4malibu's Avatar
usually you place the engine first, then worry about the trans mount/crossmember.
Old 02-13-2009, 07:26 AM
rao
rao's Avatar
No kidding
A better question would be whether they designed the bellhousing to mimic the LS1 setup (people using the ford style transmission in a Chevy) or if it was intended for use in a Ford car. Either way it opens up another option since the ford style transmissions are much more available than the GM style ones.
Old 02-14-2009, 12:11 PM
I think the site linked in my post above stated that the TKO was in the Mustang stock location. The underside shots show the trans mounted at the stock location using a trans crossmember for the TKO. The bell was for a SBC modified to fit the LS. Mods were made for the pivot ball and clutch fork opening.
Old 02-14-2009, 02:00 PM
Qwiknotch's Avatar
No kidding
yes, the quicktime bells are setup for hydraulics..
if you want to use the standard pull cable, you have to drill for the pull cable ball stud.
Old 02-15-2009, 12:07 PM
Yeah, looking at the Quicktime, Lakewood, and McLeod sites, it looks like their bells are all set up for the GM. The pivot ***** need to be moved to the opposite side for the Ford's cable shift. Seems like these bellhousings could be made pre-tapped to allow relocation of the pivot ball.
SOM68SS modified his bellhousing to put the pivot ball on the passenger side for the pull-style clutch fork.
Quick Reply: Fox manual trans options?
