whats needed to run a th400 behind a 5.3 LM7
Old 05-04-2009, 06:20 PM
BandAid's Avatar
Default whats needed to run a th400 behind a 5.3 LM7
OK i was told to search,but F@#5 there are a million pages here,and I did search and didint find what i need..
I am putting a 5.3 LM7 in my 85 Regal,want to run a TH400,do i need an adapter of some sort or iwll it cbolt right up
Thnks Dennis
Old 05-04-2009, 06:34 PM
holley505's Avatar
go to summit or HUGHES performance.
Easy way out...
buy the LS1 adapter (spacer) about $58.00
Buy the LS Flexplate about $115.00
**(you could use factory flexplate and longer flywheel bolts)
Thats it... and don't worry about the missing bolt. Thats the way GM designed it.
Old 05-04-2009, 08:23 PM
ryanvv355's Avatar
You could get the GM flexplate spacer, sorry dont know p/n, that is installed on an LQ4, then just elongate the converter holes on the flexplate. That's the cheap way.
Old 05-05-2009, 12:05 PM
w4625's Avatar
Crankshaft spacer# GM 12563532..Bolts# 12563533
Old 05-05-2009, 04:05 PM
BandAid's Avatar
thanks everyone...
Old 05-06-2009, 10:34 AM
brianjw4's Avatar
I used the GM spacer and bolts. There is an extra set of holes on the flywheel that fit perfectly for the th350/400 converters. These holes aren't raised like the others so I used a couple washers between the flywheel and converter and it works great.
Old 05-06-2009, 04:06 PM
BottleBaby Bu's Avatar
would it be to much to ask to see some pics of the flexplate with the spacer and bolted up to the converter???
Old 05-06-2009, 04:17 PM
BandAid's Avatar
yes that would be pretty cool...pics anyone..
Quick Reply: whats needed to run a th400 behind a 5.3 LM7
