6.0 crank question
6.0 crank question
I'm trying to determine if i have a long or short crank 6.0 and if i have the right flywheel to mate it to my 4l80e
Backside of flywheel
thanks in advance for the help
You have a long crank 6.0 and that is the proper (flat) flywheel. You need nothing but bolts and an engine bay for them to mate and live happily ever after.
Seriously, if the mounting surface on the back of the crank was even with the gasket you would have the "short" crank, but yours sticks out .400" so you have the "long" version.
Wow, howsabout that! I've got a one-off Corvette motor! As far as I knew, only certain trucks came with the "long"cranks. Here's a pic of the stock '03 C-5 engine (transplanted in my Maverick) undergoing a rear main seal job. Looks like the same crank as yours. This particular crank (whatever the "length") required the spacer and bolts to mate up a 200R4. Guess you better solicit some other opinions...
i appreciate all suggestions on this.... i've been looking around for that magic post with a picture of the long crank in comparison to the short but hadn't had any luck so far...
the flywheel i have is flat.... i know it didnt come off the motor that i have so that is mainly why im trying to determine if this is right combo before i bolt all this in
if you have access to take the oil pan off and look at the casting number on one of the counter weights you can tell by that.
All of the '99 - '00 cranks had the 12552215 casting with the wide flange.
All of the '01-'04 cranks used the 12552216 casting with the narrow flange.
the one on the left is the 12552216 which is the narrow flange, and the one on the right is the 12552215 which is the wide flange.
