AArrgh! Water--lots of water--in the oil pan of my 3k junkyard L96. What next?
Got all the junk off my 3k mileage junkyard 2010 L96 last nite, and pulled the oil drain plug and immediately out comes about a gallon of water or coolant. Then the oil finally starts to come. Don't know how the water got in, and not sure what to do next. Maybe it came in thru the opening on the passenger valve cover? Here are two pics w/valve covers off--drivers side looks great, but passenger side has rust on the one spring where the oil opening is. Had no cover over oil fill hole when I got it.
Plz post any response on my build thread:
https://ls1tech.com/forums/conversio...dayton-oh.html
What do I need to do next?
I may not have that option. But it is also in Gary IN 5 hours away. So really two ?s. Given that volume of water, it obviously happened post wreck or the engine would have already died. So what damage would water going thru the engine do? Especially since it all went down to the bottom of the oil pan and was sitting there? Probably some surface rust, but pistons all move freely.
In a first best world I wouldn't start this way, but if I am where I am, I need to understand the risks prior to going forward. I mean, it would be more work to add it all back together and ship back than to pull the heads an put new head gaskets. I'll be replacing the pan anyway.
Anyone w/knowledge of how the oil drain holes work that can tell me what potential damage I could have? Any theories as to whether coolant could have somehow got in w/o a blown head gasket if the engine was upside down during the wreck (which I don't know, but is possible)?
I'll probably rotate the engine and take off the pan tonite. Pictures to come.
Was it coolant or water; it's not clear from your description. With that much water, I suppose it could be a "flood motor." With as much rust as I see in the photos, I would be highly suspicious of rust on the cam and lifters (actually the whole valve train like valve stems, etc); not a risk or investment in time and $$ I would personally want to deal with, and a return to the yard would be my option.
Andy1
Andy1
Just got off the phone w/the junkyard; yes there is a 30 day warranty. However, the guy is pretty convinced that they must not have sealed the oil hole prior to their PRESSURE WASHING it. So now we have a good idea of the source of the volume of water. He asked if I had taken the intake off, which I had, and he asked if there was any water in there (said I would hear sloshing). I replied there was none, so he doesn't think any went down the intake thru to pistons. He is pretty convinced it should be fine. I'll look at the crank and everything tonite.
If it is ok, I'd sure just like to keep it--huge hassle to ship back.
yeah man... thats really shitty, but i think that not taking it back is gonna be a real can of worms.
even if it was JUST some light surface rust, like andy said, its probably over parts of the valvetrain, could have effected bearings, etc. Remember that if you do keep it it MUST be fully cleaned, all the oil/coolant passages etc etc; rust is like mold, so once it starts itll spread wherever. the engine might turn now but itd suck to find out down the road that the cylinders were pitted or the cam lobes got roughened, etc.
i would have been on the phone w the yard as soon as i saw that rocker
EDIT: did you show the guy at the yard those pics? im still of the opinion that its less work to ship it now than to pull it/rebuild later
I had that EXACT thing happen to me, they BS'ed around for a while, too long for me and finally after I told them I would put it through their front window they refunded me, the whole time saying they never heard of an LS motor getting water in them, they are a sealed motor....yea BS! I got a better one from LKQ
Get em to get you a new one and they can pay to ship them both..... Don't be concerned with the hastle shiping it back. slap it on the skid secure it good enough, so when the truck comes to drop off the new one the old one goes back on the same truck. Like stated before the valve train in that area is most likely contaminated with surface rust. So if you were not planing on rebuilding the motor it is not worth keeping.
