LS1 swapped, car won't turn off now.
Old 04-10-2011, 12:23 PM
Don Nguyen's Avatar
Default LS1 swapped, car won't turn off now.
Been trying to wrap my mind around other various electrical gremlins at the moment, and this is the last one on the list, and my mind is a bit burnt out.
The car turns on and everything functions just fine. However, the car will not turn off with the key in the off position. All of the in car accessories, etc, will shut off with it in the off position.
So issue is, the fuel pump is constantly priming/pumping regardless of the key position in the car or not, and the car won't shut off once turned on.
Any suggestions? My first thought would be a switched power wire is attached to a constant power wire, but it seems like I have this wired up correctly.
Old 04-10-2011, 12:43 PM
RATBOX's Avatar
Remove both your constant and key power connections, try different ones and see if that remedies it. That way if you remove them and it stays powered, then maybe your starter connection is firing everything? Are you using a harness you made yourself or a vendor harness?
Old 04-10-2011, 12:48 PM
Don Nguyen's Avatar
It's a harness that I made.
Old 04-10-2011, 05:40 PM
Pocket's Avatar
All 3 of the no-shut down harnesses i repaired has this issue
Unplug the PCM and test the IGN, batt and INJ 1/2 fuse wires
Old 04-10-2011, 06:05 PM
Don Nguyen's Avatar
Found the issue. One of the factory (BMW) PCM relays had two 12v constant wires. Snipped the one that wasn't constant originally for the LS1 and wired it up as a switched on 12v wire, and now everything functions as normal.
Old 04-10-2011, 07:37 PM
Don Nguyen's Avatar
I just noticed that the fuel pump is constantly priming/pumping with the key in the 2nd accessory position. With the key in the 1st accessory position the pump is not on, so that's fine. Not sure if this is normal or going to be any issue later on down the road.
Old 04-11-2011, 12:52 AM
RATBOX's Avatar
Well, is the pump wired to have the computer controlling it's voltage? Obviously if so it should only see 12 volts for a couple seconds. Sounds like it's simply seeing constant 12 volts with the key forward.
Old 04-11-2011, 07:42 AM
Pocket's Avatar
Pin 30 or the ORN wire gets fused battery power
Pin 85 BLK/WHT is grounded
Pin 86 DK GRN/WHT gets 12v IGN from the PCM
Pin 87 GRY is putout to fuel pump
Old 04-11-2011, 10:46 AM
Don Nguyen's Avatar
Yep, that's how I have it wired. I have it wired to the green/white on the C connector instead of the wire coming off of the PCM directly. I am assuming that should be ok.
Old 04-11-2011, 09:26 PM
LS1MCSS's Avatar
You need to let the pcm control it so it works the way it's supposed to.
Old 04-11-2011, 09:58 PM
Don Nguyen's Avatar
The color on the C connector is the same as on the PCM. I figured/thought it went to the PCM as well?
Quick Reply: LS1 swapped, car won't turn off now.
