Ls7 intake on lq4?
Old 08-27-2011, 08:47 PM
mrhotrod69's Avatar
Default Ls7 intake on lq4?
Ok i have an all aluminum 5.3 and 4l60e from a 08 tahoe.i'm not sure what the correct ls series it is or what l code it is.i got a 2010 camaro intake maunifold will it work on this engine? My motor has the plate under intake with cylinder shut off solinoind
valves.also what kind of dbw pedal can i use the tahoe 1 is pretty bulky.any help will be very helpfull!!!!!
Old 08-27-2011, 10:27 PM
Jimbo1367's Avatar
a LQ4 is a 6.0L. The 2010 Camaro intake manifold is from a LS3, not a LS7 as your thread title says. (LS7 is the 427CID from the Corvette. I don't recall the displacement in Liters. )
You don't have the correct heads (LS3 or L92) to use the Camaro intake manifold. Nor can you install them on your 5.3L. You need a minimum of 4.00" bore for the L92/LS3 heads. The valley plate is referred to as DOD(displacement on deemand) for what its worth. Someone will chime in on your TB question.
Sorry my reply is all over the place.
Good luck,
Jim
Old 08-28-2011, 03:57 PM
armour's Avatar
Let me see if I can help clarify. You want to mix and match a different pedal with the stock tahoe throttle body?
Old 08-28-2011, 04:30 PM
Marcello7x's Avatar
you need to swap heads. Cathedral port vs square. Go with an ls6 or fast if your keeping stock heads.
Old 08-28-2011, 06:03 PM
mrhotrod69's Avatar
ok I done some searching today my intake is from a 2010 camaro ls3 my engine is an 08 truck 5.3 not 6.0 still needing to know if intake will work and what type of pedal i can use with a dbw throttle body also who can I get a computer from ready to go? THANKS
Old 08-28-2011, 06:46 PM
the_merv's Avatar
That Intake will not work. You need something that is Cathedral.
Old 08-28-2011, 06:54 PM
yonerhottlt1's Avatar
What he said!
Old 08-30-2011, 10:42 AM
mrhotrod69's Avatar
where can i find 1 or how can i trade my rectangle port to 1?
Old 08-30-2011, 12:06 PM
the_merv's Avatar
You can find them anywhere..what are you exactly looking for or wanting?
Quick Reply: Ls7 intake on lq4?
