Dmax and a third gen
Old 10-02-2011, 10:28 AM
lunati397's Avatar
Default Dmax and a third gen
I know this hasnt been done yet but I and taking on the challenge I got a 2003 donor truck 2500 2wd 6.6 duramax I have it striped down and I have my 91 camaro with no engine and trans
I want to get in the 600 hp range with the duramax and ill have a built 4l80e behind it
Ill start test fitting the engine next week and will keep you guys up to date I am not rich just lucky and came across some good deals but this will not be a overnight swap and I am aware of all the custom fab work ahead of me and I am very capable of taking it on
YES subframe like a ****
Old 10-02-2011, 12:29 PM
zipster's Avatar
Sounds cool, I saw a sn95 Mustang with a Duramax at the Texas Mile. very different.
Old 10-02-2011, 03:00 PM
lunati397's Avatar
he ran a 202.5 i think thats the ceo of nitrous express kinda the same setup im shooting for
Old 10-02-2011, 03:09 PM
02SSISFUN's Avatar
gonna be baddass
Old 10-02-2011, 04:21 PM
Blownz28man's Avatar
Interesting.. So many have talked about it but no one (to my knowledge) has done it. Curious how it'll fit? Think it'll fit between strut towers?
Old 10-02-2011, 04:52 PM
the_merv's Avatar
There was a guy that did the old 6.5 in a 4th Gen..goin to need some good front suspension..lol
Old 10-02-2011, 11:03 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
You'll be my hero if you pull it off...Duramax swaps are awesome.
You are going to need a stout 4L80 to handle a 600 rwhp Duramax (800+ ft/lbs).
Good luck!
Old 10-03-2011, 01:42 AM
59 camaro's Avatar
good luck, cant wait for pictures
Old 10-03-2011, 05:00 AM
Captain Double Post
BOBS99SS's Avatar
yeah i would love to have one im my car , that would be so badass, i saw a 71 camaro with the swap and that car was such bad ***, and was fast as hell, good luck man ,
Old 10-03-2011, 09:26 AM
lunati397's Avatar
the 4l80 will be fully built with the toughest components it will definately fit width wise the height is the issue but I can remote mount the turbo(S)if needed I have a 2 inch cowl and do not want to go any higher than that
I will be taking lots of pics and posting the swap
Old 10-03-2011, 09:44 AM
1CAMWNDR's Avatar
Epic.
I vote for 1 F1 procharger overdriven so it makes 2-3 psi right off idle and 1 healty turbo.
Old 10-03-2011, 12:25 PM
Jimbo1367's Avatar
Originally Posted by 1CAMWNDR
Epic.
I vote for 1 F1 procharger overdriven so it makes 2-3 psi right off idle and 1 healthy turbo.
Can we(he) count on your checkbook to help make this happen? lol Seriously. If you have any $ left afterwards. maybe you can fund my stagnant swap.
Old 10-03-2011, 01:06 PM
lunati397's Avatar
there are guys doing it with a compound twin setup with a s480 feeding the stock and getting up to 60 psi thats about as high as I will go actually I want to keep it around 40 until I build up the bottom end
the diesel world is alot different you can mix match lb7 lly lmm stock parts and make one strong engine but alone they all have their weaknesses
also you can get big power for cheap if done correctly
Old 10-03-2011, 01:27 PM
1CAMWNDR's Avatar
If the compound turbo is cheaper since you don't have to buy a second turbo if feeding the stock one then that is a winner. None of it will be really cheap including any fabrication; but an F1 Procharger for instant boost off idle and then a decent turbo to feed the top end sounds like the ultimate solution to me. Maybe that can be the upgrade later down the road .
Old 10-03-2011, 01:29 PM
1CAMWNDR's Avatar
****, I can barely fund my $6500 Bandit......
Old 10-03-2011, 07:23 PM
ponjohn's Avatar
600HP and prob a 1000 ft lbs. Good luck hooking that up.
I think this is an awesome project.
What does a Dmax weigh?
Old 10-03-2011, 08:34 PM
the_merv's Avatar
Ya with that power it needs to be mounted over the rear axle..lol.
Old 10-04-2011, 07:25 AM
lunati397's Avatar
820 fully dressed I will be relocating the battery and lightening up the front end as much as possible
I also plan to either back half the car or just a mini tub to put some rubber under there
Old 10-04-2011, 08:39 AM
1CAMWNDR's Avatar
And try to mount the engine as close to the firewall as possible. That might be another reason to mount the stock turbo somewhere besides the stock location.
Old 10-04-2011, 09:57 AM
lunati397's Avatar
Im going to mount it as far back as I can without modifying the stock firewall and going to coil overs with a high lb spring
