finding a complete t56 harness
Old 05-16-2012, 02:11 AM
mdrn69velle's Avatar
Default finding a complete t56 harness
I have a 98 pcm and what used to be a 4L60E harness scored both for $75 BUT its missing every wire rear of the motor they just cut the harness and I'm guessing I'm missing every trani wire where can I get a complete t56 harness to splice to mine. I seen the website's that sell plug by plug trying to avoid that only doing that as my last resort.
Old 05-16-2012, 05:01 AM
LS1MCSS's Avatar
All you reall need are the VSS wires. You can do without the rest. Just get a vss plug and run the two wires to the front. Solder the wires to two of the pins you will have when you remove unused wires and plug them into the pcm..
Old 05-16-2012, 07:51 AM
oange ss's Avatar
backup switch and reverse lock out wiring highly recommended.
Old 05-16-2012, 10:12 AM
bczee's Avatar
There are four connectors for the T56 that you can add/mod. You don't need any of them to run, but as noted, Some are Highly recommened as they make life easier and does add value to driveablity (PCM will control Idle on slow down and stopping).
I drove with only the Reverse Lockout wire for a year, then added the Reverse Light switch, I still don't run a VSS. But have not had any problem with low idle or engine stalling when coming to a quick stop. I may be one of the lucky one. ??
1) VSS - Recommended
2) CAGS (don't need, can be removed and plugged)
3) Reverse Lockout - Recommended, else you have to slam over the shifter to get into reverse. Some have removed and plugged, but be carefull on going from 6th to 5th, as you might go into reverse.
4) Reverse Light Switch - Recommened, just wire into your old wiring.
BC
Old 05-16-2012, 12:01 PM
sweet. thanks for the info Ill just do those 4 plugs since I'm there doing it. Anyone know part #'s to those plugs? My pcm harness is a 98 not 99+ but the trani is a 2002 don't know if that matters or not.
Old 05-16-2012, 12:07 PM
the_merv's Avatar
All the T56's are pretty much the same.
I only wired 3.. VSS, Reverse Lockout, Reverse Lights. Cags is useless garbage.
You can buy the connectors online, of clip them from a harness at the junkyard. I think I have a few of each layin around from harness that I've stripped to build others.
Old 05-16-2012, 12:12 PM
bczee's Avatar
Check out this Thread..
https://ls1tech.com/forums/conversio...onnectors.html
BC
Old 05-16-2012, 09:09 PM
If you find them and wanna give them a good home let me know lol..
Junk yards around here with ls1 and t56 are gold, theres a few but they go quick.
Old 05-16-2012, 10:28 PM
the_merv's Avatar
How soon would you need them? I have them boxed up.. Would take a little but to find them where I have it all at.
Old 05-17-2012, 02:53 AM
No worries but if u find them that would be cool. But the trani is coming mid next week and I'm picking up the motor from the machine shop on tues or wed so won't start harness till probably memorial weekend.
Old 05-17-2012, 11:03 AM
I looked at the harness last night again and its a few fires that were snipped. Im guessing I'm going to need some o2 sensor wires as well, may go to the junkyard today and get the plugs off a v6 I need a obd plug anyways. Should be the same as a LS1 right. heres a pic of what was cut
Old 05-17-2012, 11:07 PM
the_merv's Avatar
That's more than a few wires..
All in the Trans harness?
Old 05-18-2012, 12:05 AM
bczee's Avatar
Yup.. going to be Fun !
Old 05-18-2012, 12:30 AM
tt383lt1's Avatar
ill make it easy for you i got the whole t56 harness for $30 and you pay shipping.
Old 05-18-2012, 12:42 AM
the_merv's Avatar
Good deal there.. The part from the Trans?
Old 05-18-2012, 02:05 PM
lol thats why i said in the op its everything rear of the motor my guess is that its the whole trani harness and all 4 o2's wich is is about 2 wires per o2 makes it 8. idk ill figure it out once its all getting plugged in.
done usps "$5 if it fits it ships" :use:
pm me your paypal
Old 05-22-2012, 12:29 AM
Any luck on finding anything?
Quick Reply: finding a complete t56 harness
