Hesitation/popping only when fan comes on.
Old 09-02-2012, 03:25 PM
rp0029's Avatar
Default Hesitation/popping only when fan comes on.
So my car, a 1968 camaro with an lq4 enqine,ls3 heads, GM computer, ls3 intake, and a 222/230 cam runs like a raped ape. The throttle response is amazing, the car has teriffic street manners, the 4l80e chirps the tires into second and third, everything you would want in a dd conversion.
Then the fan turns on.
It becomes a completely different car. The car hesitates on light throttle, pops out the exhaust on acceleration, and is down on power.
I have a Lincoln mark 8 fan, and an internal walbro 255 pump. Aside from the stock GM engine electronics, no other electronics are hooked up. My alternator is a 105 amp stock. Is it not putting out enough juice? What else could this be?
Old 09-02-2012, 03:26 PM
rp0029's Avatar
Bad grounds maybe?
Old 09-02-2012, 03:36 PM
Chrome_Rust's Avatar
I would start there and see what happens. Try wiring up the fans directly to a switch from the battery. WHen the computer commands the fans to power on, it will only energize the relay, not the fans. And you can drive the car and it not over heat, but see if it is a power draw, or something in the tune.
Old 09-02-2012, 04:26 PM
Jesus Freak's Avatar
The fans not blowing in/on or around the air filter?
Could be too much of a power draw, I know those fans draw a lot of current. I run a 140A alt, might be worth looking into an upgrade.
Old 09-02-2012, 05:07 PM
rp0029's Avatar
OK I will try this tomorrow.
Old 09-02-2012, 06:01 PM
rp0029's Avatar
I've also ordered the torque elm scanner. Will be here friday.
Old 09-03-2012, 08:32 AM
Pop N Wood's Avatar
The fan could be loading down the power circuit to either your computer, coil packs or injectors. It might also be putting out a bunch of electrical noise that would do the same. Running it straight off the battery will probably tell you.
Believe it or not I have had dirty battery posts cause a similar issue. Car use to momentaryily stall every time I turned on the turn signal.
Old 09-03-2012, 08:58 AM
rp0029's Avatar
Thanks for the reply. Battery is brand new yellow top. Got it a month ago.
Old 09-03-2012, 09:08 AM
rp0029's Avatar
I actually just tried to wire my power circuit directly to the alternator, and did the same with my fuel pump. No dice. It just could be that the tune falls out of whack above a certain iat temperature. Or it could be that the fan draw too much juice for the alternator.
Old 09-03-2012, 09:32 AM
Old Geezer's Avatar
Data log it and see what happens to the voltage when this happens....
Old 09-03-2012, 11:54 AM
rp0029's Avatar
Can I do that with an android app? I used to have an elm 327 but my laptop crapped out.
Old 09-06-2012, 07:23 AM
rp0029's Avatar
Well it doesn't appear to be the fan. The hesitation and popping occurs even at 125* now. It boils down to plugs, wires, fpr / filter, investors, pump, or tune. It is really frustrating.
Old 09-06-2012, 07:24 AM
rp0029's Avatar
The tune is a bit rich. Perhaps it is fooling my plugs. Wires are brand new.
Old 09-06-2012, 07:32 AM
rp0029's Avatar
The car seems to "miss" at idle.
Old 09-06-2012, 10:11 AM
74modified's Avatar
If you have both speeds of the fan wired to be on at the same time, instead of only low or only high. Try disconnected one speed.
Old 09-06-2012, 02:37 PM
Pop N Wood's Avatar
What is your voltage gauge reading with and without the fans running?
If it is staying at 14 V then it is not an alternator capacity issue.
Old 09-06-2012, 05:34 PM
rp0029's Avatar
Voltage drops slightly. The problem is getting worse. Now It pops constantly, fans or no fans. My obdii gets here tomorrow.
Old 09-07-2012, 02:16 PM
rp0029's Avatar
Ok so i started the car in the parking lot. Got maf code, and vacuum is at about 18 at idle, crashes to about 6 when in gear. No other codes. I guess i should check the maf, no? Is there an easy way to do it?
Old 09-07-2012, 02:32 PM
Pop N Wood's Avatar
I think you need to find your vacuum leak. Is there some type of vacuum modulator tied to the trans?
Old 09-07-2012, 03:44 PM
rp0029's Avatar
No. Trans is 4l80e. So is a vacuum leak the consensus?
Quick Reply: Hesitation/popping only when fan comes on.
