70 chevelle TH400 dipstick
Old 01-30-2013, 11:59 AM
psi3000's Avatar
Default 70 chevelle TH400 dipstick
I want to know if anyone has had any success with a particular dipstick when using a TH400 in their ls build on a A-body 67-72 should be the same i would think. I have heard some horror stories when using the flexible lokar flexible ones when filling among other issues. Has anyone had any success with them? Also I hear any repo ones will not fit and instructions call for you to BEND IT to make it fit! Let me know what you have found to work.
thanks
Old 01-30-2013, 12:07 PM
1989GTA's Avatar
I am about to find out. I am going to try the factory dipstick when I install a 6L80 in my 1965 Buick Skylark. When searching for the part number it appears that the 4L80 and 6L80 use the same transmission dipstick.
Old 01-30-2013, 01:08 PM
psi3000's Avatar
Thanks for the replay but I am using a Turbo 400 or TH400 transmission, the old school kind. I dont know if this information would prove useful. thanks though.
Old 01-30-2013, 01:10 PM
ls1_chevelle's Avatar
no horror stories with my lockable lokar dip stick. TH400.
before the 400 I had an 80e in the car. Stock dip stick tube worked, but HAS to be installed before the trans is in the car. Atleast on my setup.
Old 01-30-2013, 02:53 PM
LS1Tech Sponsor
psiconversion's Avatar
I have used the flexible lokar cable as well and had no problems.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 01-30-2013, 03:15 PM
psi3000's Avatar
ls1 chevelle is that the non-flexible "top-hat" i think they are called one? thanks for the reply guys.
Old 01-30-2013, 03:19 PM
psi3000's Avatar
ls1_chevelle you got a part number?
Old 01-30-2013, 04:04 PM
punch this into summits site.
LOK-XTD3350400FM
They make a shiny stainless version for cheaper
Old 01-30-2013, 06:34 PM
psi3000's Avatar
Actually like the black one more. I hate too much chrome. Thanks a bunch guys. If anyone has any other ones that work please post as this is a issue with a ls swap in a bodies . T have found a couple different forum while searching on google with the same issue. I saw one option was to cut the bent section out and replace it with 3/4 inch heater hose.
Old 01-30-2013, 07:23 PM
71Fakes's Avatar
Do you know if the 4L80E and TH400 dipsticks are the same?
I have a Lokar flexible for a 4L80E sitting around collecting dust. If you are interested, PM me and I'll make you a great deal.
Old 01-30-2013, 07:42 PM
psi3000's Avatar
How long is it? Do you have a part number?
Old 01-30-2013, 07:47 PM
psi3000's Avatar
Just checked summits site , it seems they are different numbers.
Quick Reply: 70 chevelle TH400 dipstick
