67 chevelle 6.0 lq4 w/4L80E build
Old 08-19-2015, 09:29 PM
19chevelle67's Avatar
Default 67 chevelle 6.0 lq4 w/4L80E build
Been a follower 4 a bit now read through so many threads just got more confused the more i read on lol, but any who just starting my 6.0 lq4 with 4l80E swap. Had 283 with 2speed power glide
Sittin pretty at lone star round up
Gettin ready for a little cruise
Old 08-20-2015, 12:53 AM
67Skylark's Avatar
Looks like a nice ride, should be much nicer with a 6.0 and OD
Old 08-20-2015, 10:24 AM
66Chevellelq4's Avatar
Sweet ride. What are your plans? Bone stock?
Old 08-20-2015, 08:31 PM
john 67's Avatar
keep the pics coming .nice stance
Old 08-21-2015, 06:50 AM
kwhizz's Avatar
Hint !!!!..........Holley 302-2 Pan..........Will eliminate tons of issues later.....
Old 08-21-2015, 08:59 AM
Alwhite00's Avatar
What he said, mine fit like factory.
Old 08-22-2015, 01:51 PM
I did end up ordering 302-2 holley pan and used ict billet adapter plates, were bout 50 bucks, was going 2 go with dirty dingo but for 50 bucks couldn't beat it. I can mount the motor in different positions
Old 08-22-2015, 01:54 PM
As of rite now yes i want 2 get her running 1st then if all is well put a small cam in and some headers, on a tight budget but one day she'll be running
Old 08-22-2015, 02:11 PM
Was like xmas
A buddy and i were drinking one day and decided 2 pull the motor, woke up the next day and said 2 my self what did i do lol so she's been out of commission for bout a little more then a year and a half
Gonna try to install complete
Motor with holley pan on
Old 08-22-2015, 02:21 PM
Never try installing on your own its truly a 2 man job, you always need an extra set of eyes to see what's hitting and what not
Well long story short had to remove manifolds intake and passenger side coil packs cause all were hitting
Old 08-23-2015, 04:36 PM
Alwhite00's Avatar
FYI my 4L60 is really tight in the tunnel. If I jack it up 1/2" off the xmember it hits the floor. Just be ready to do a little clearancing with that 4L80
Old 08-23-2015, 07:04 PM
Brian Hoss's Avatar
Wish your pictures were visible! What mounts are you using?
Old 08-24-2015, 10:01 AM
Alwhite00's Avatar
I can see the pictures.
Old 08-24-2015, 06:14 PM
Im using standard OReilly auto parts mounts nothing fancy no name, just got wat i needed for my 283, the ict plates bolted up nice, just move the mounts one space forward to set motor closer 2 fire wall and clear cross member, i think if i had ordered the holley 302-1 pan it would sit pretty much stock location but the 302-2 has a bit bigger sump then 1st, but then there's tie rod issue. Ill get closer pic of mounts. Btw are u the same Brian over on chevelle site?
Old 08-25-2015, 08:10 PM
Motor sitting in bay
Had 2 remove power steering pulley, still cleared but it was so close i couldn't get belt off. I still haven't put trans cross member on but i did jack it up to where i think it would sit
Old 08-25-2015, 08:17 PM
When i was installing motor i thought i might have 2 cut into fire wall/trans tunnel area but slipped in just at right angle, as of right now its in there but once i install cross member we shall see
Old 08-26-2015, 10:12 AM
I used a ford power steering pulley, clears great and i got it from a junkyard
https://ls1tech.com/forums/conversio...swap-pics.html
here are some more tips if you haven't come across this page
https://ls1tech.com/forums/conversio...2-gm-body.html
Old 08-27-2015, 01:57 AM
Brian Hoss's Avatar
Cool. Good to see someone use the ICT LS adaptors. Will be good info for someone else down the road. Yup. The same Brian Hoss on Team Chevelle. When you get it all mocked up, please post the info over there and I'll add it to the database!
Old 09-29-2015, 06:56 PM
Here's a few pics of the ict adapter plates
Old 09-29-2015, 07:10 PM
Well i tried installing the trans cross member this passed weekend n had no luck, the trans hits the tunnel before i can get the tail end high enough to clear cross member, so im going 2 have 2 ethier remove trans and install separately or raise body up. Don't feel like removing trans so probably going to raise up body. Once its in i shouldn't have any clearance issues with body but ill have to wait and see
Quick Reply: 67 chevelle 6.0 lq4 w/4L80E build
