4l80 Converter
4l80 Converter
Hi all,
Ready to buy the converter for my build but need assistance as to which stall speed to get.
69 Camaro
lq4/6.0 with 243 heads
4l80e
228, 113 lsa cam
3.42 gears
Will be a weekend car, occasional track.
I was thinking the yank 3200? Any help is greatly appreciated. Also if there is a thread with this info already I'll gladly check that out.
thanks!
69 Camaro
4l80e
228, 113 lsa cam
3.42 gears
thanks!
I have nearly the same engine combo but a 4l60e and 3.90 gears. I have a yank ss3200 and it's about perfect. I can even drive it in the snow. If you're light on the throttle it'll drive like a stock converter. If you get into it, hold on! It'll flash and destroy tires!
Converter
How did u get the converter to fit the lq4? Im running into that problem i called circle d and they said they cant make an6 bolt converter for my stock flywheel
I also went with a 3000 Circle D. With VVT I don't necessarily need a very high stall and I was more worried about having to deal with an irritating loose converter. I can't wait until the roads clean up so I can try it out!
