Hooker 1964-67 A-body LS swap system preview thread
#202
The frame adapter brackets that come with the crossmember align with the stock holes in the 64-66 frames as well as the 67 frames. You have to drill two holes through the vertical walls of each frame rail to complete the install of the brackets and then the crossmember gets bolted to the top of the adapter brackets.
#204
Yeah, I'm happy with the results and the extra weight that is associated with the frame adapter brackets (1/4" steel plate) comes with the benefit of added frame stiffness. A T56 or 4L80 can also be much more easily R&R'd due to the multi-piece configuration.
#206
Yes, things are progressing at the usual rate. The engine bracket assemblies are in our distribution facility and awaiting boxing. The header production fixtures were just completed this past week, so they can be ran during the next 1-7/8" bender tooling set-up. I don't recall the part numbers off the top of my head, but I can post them up next week for you.
#208
There is progress to report on the release of the parts. The engine brackets were released into the system on Friday and there are sets of both the forward bias and rear bias versions on the shelf; the part numbers for the engine brackets are 71221008HKR and 71221009HKR. They shound be listed on the Holley website and be available for purchase sometime next week. The transmission crossmembers have been delivered to our distribution facility and are waiting for our internal documentation process to catch up with them so they can be boxed up and put on the shelf...I'm going to guess 1.5 weeks for that to happen. I've been informed by the production lead that the first production run of the 1-7/8" long tube headers should take place the week after next.
#212
Just read the whole thread from beginning and so happy for this "system", but I'm biased
For those debating 1-3/4" Vs 1-7/8" headers....
Not surprised but if you are building a +.600" cammed or 6.2L, the bigger header is a no brainer. Personally, I'd only use the bigger header on an LS.
Then again, how sexy would black ceramic coated 1-7/8" header with the new Holley fabricated "Sniper" (black) and polished ARP bolts everywhere
ps. Good job Holley/Hooker and Todd. Been using both products for just over 30 years.
#213
Question from outside the box
Todd,
Great job on the fabrication of this stuff it looks great!
I do have a question about something a little out of the ordinary here.
I am planning on using your front mounts and headers and considering the cross-member but I am mounting a G8 l76 (ls2) and a 6L80e. I understand this was not within your design spec. My plan all along has been some pretty serious floor surgery to get the big box in there and achieve usable driveshaft angles. I have adjustable rear upper control arms on the rear end. here is my question.
Will your rear cross-member come close to putting the 6L80e in a reasonable driveshaft alignment but just with the disadvantage of carving up more tunnel space to house the large upper portions of the 6L?
I planned on the forward spacing to give myself some room around the engine / bell housing for the much larger upper front on the 6L80.
Just trying to see if your crossmember would give me the base alignment or if I should just start from scratch and fab something. I hate to cut up your beautiful work to pursue the 6L80 transplant.
Thank you for all your efforts to help all of us achieve LS nirvana
I am lowered about an inch or so.
#214
Todd,
#215
Thanks Todd! I totally understand.
I am hoping to keep the tunnel mods confined to the area in front of the rear seat and the floor bracing back there.
I will share my pains if you are interested to help others be wiser than I......
#216
#217
I am in the process of the same configuration. I have the G8 that my engine came out of. My plan is to use the tunnel from the G8 and graft it into the 65 Lemans. If that is not possible, then I will cut the tunnel and do what I have to to make it fit.
#218
Hey guys. Both sets of the engine brackets are now listed on the Holley website and are available for purchase. The transmission crossmember will be the next up to get released and the 1st run of the 1-7/8" long-tube headers should take place next week.
#220
Yessir. Already ordered the brackets. Eagerly awaiting the other parts!!!
