Foxbody notch lq4 turbo build
#101
Mounted the fuel rails today on the the intake. These are from Holley ment for the ls1 intake. I was going to make some brackets to hold them down, instead I was able to use a bolt going up through the bottom of the intake mounting hole and the brackets that Holley supplied.
#104
Couldn't use the threaded rod to secure the pumps. They have to sit at an angle so the hose won't kink. The plastic piece that the stock bucket sits in does the job of holding them from moving around too much.
-6 adapter on the stock feed for the return fit on I re used it from the factory fuel rail I was using for fuel supply.
#106
I would drill some holes in the basket to ensure that you dont run it dry while under fuel throttle. Just my .02 , I love the build though. Been trying to track down a reasonably priced notch for a while, if i ever come across one ill just rip the guts out of my 04 and drop it in... Gotta love AJE lol.
#107
I'm just gonna use this setup for the Dyno. I really didn't spend much on modifying the hat so wouldnt be much of a loss. Before I do any track runs I'll try and find a baffled tank along with a tripple pump hat. I don't want to risk going lean and burning piston just for trying to save a few hundred bucks.
#111
Got the fuel system all wrapped up. Engine bay looks like a damn birds nest. There's hoses and lines running everywhere seems like. 3 of the fragola 90 degree fittings are leaking. They are connected to orb fittings from Earl's figure the mismatch must be the cause. Ordered some earls fittings. Strange though two 180 degree fittings are fine.
#115
The little factory foxbody 4 banger drive shaft held up long than I expected. I'm gonna start making some real power so upgraded to the larger 1350 u joints and rear end flange.
Chromoly sonnax 4l80e slip yoke. This thing is a beautiful piece.
