Foxbody notch lq4 turbo build
Well here we go again. Some of you may remember the recent build thread where I went through the LS swap. Ran the car at the track best Et was 11.9 and 120 on motor and 11.3 on nitrous. Now I'm going turbo!!!
Got an intercooler kit from CX racing.
Turbonetics 7668 ball bearing turbo. Should be good for 550 wheel.
Truck manifolds with v band flanges.
curious on your 3" setup..as i have to put one on my ls notch..are those the speed eng. headers? if so mine look like the d.s. header exhaust pipe cant go straight back to the rear as the stock crossmember mount (at the sub-frame) will be in the way? are you still using stock location trans cross member? thanks for the info!
Cut into the frame so I could move the turbo out away from the water pump. Later I'll box it up.
It was a little tricky but we made a S and U curve off the passenger side manifold to the flange.
Merge pipe complete I think it came out really good. I still need to put a flex joint.
I know the hole looks big but I plan on cleaning up the engine bay when I build the motor so I'll make it look pretty later.
This is just below the turbo mount on the passenger side plenty of room for the waste gate. Just need to get some tubbing to mount it it and it's pretty much done.
I was gonna drill a hole in the fender but decided it would be much cleaner running it towards the ground.
How you mount it is more important than where. You want it to be at an angle in the same direction as the exhaust flow. A picture is worth a....you know.
http://www.turbosmartusa.com/technic...egate-fitting/
As for where, I have a preference to put it right after the 2 pipes merge, but space, turbo placement and the merge collector design forces your decision.
