Possible to Retrofit Volt or Prius AC compressor?
I'm in the researching phase of my future AC build, but I came across a bunch of Cheap Chevy Volt AC compressors and was wondering if this could be an option for installing with Vintage Air? They are self contained and won't need to be driven off of the accessory drive. For me personally with the CTS-V accessories there isn't an option any longer for low mounting an AC compressor, so this would be ideal to use since it can be placed anywhere. I thought I read somewhere that they ran at a much higher voltage though? I tried doing a little research, but didn't come up with much. Thought I would turn to the folks here that are much more knowledgeable with electrical systems.
Thanks,
Ryan
I was reading an article recently that was discussing the Volt accessories and it mentioned that only the drive motors run at high voltage. The accessories such as radio, power windows, electric fans and etc run at 12v. I'm going to dig further into this.
I'll look into the load requirements for the setup. It's probably not going to work, but figured it was worth a look.
In your case, It's not a cheap way to go, but LSX concepts has different 8-rib drives that will move your stock tensioner out of the way enough that I think you can then high mount a Sanden SD7 up high on the passenger side off the 6 rib belt.
https://www.lsxconcepts.com/collecti...uty-race-drive
There's an LSA swap group on facebook, with a lot of good posts, you might find some info there.
Haggar, thanks for the info on the Volt AC unit. Looks like those will definitely not work for the current and voltage requirements. My alternator is only a 165 amp unit so I'm limited there again because of space. I go over that in my build thread.
https://www.cruisencomfortusa.com/hot-rod-series-1
https://www.ebay.com/itm/28436360016...oAAOSwQ-pg5JDd
