Another harness option....
Old Jan 14, 2008 | 12:26 PM
jw33's Avatar
Default Another harness option....
****UPDATE THE ECM WAS ABLE TO BE TUNED WITH HP TUNERS****
See the last post in the thread for details....
Just recieved the new harness kit from GM for the LS2/3/7 motors. I ordered the kit for the LS2 p/n: 19166568. It comes with a harness that is completly labelled, what looks like a E67 ECU, throttle pedal, (2) O2 sensors with bungs for your headers, a MAF with the bracket to mount it into your intake tract, and a set of instructions. The fuse block has all the relays and wires ready for your fuel pump and cooling fans along with MIL in the center. There is also a MIL, VSS output, Tach output, and Oil pressure output among other things that are in the bulkhead connector that go inside the car along with the diagnostic port The best part about the kit though is the price.... $815 from Scoggins Dickey. Hopefully it works as good as it looks.
Kit
ECU
Fuse block
Sensors
connector labels
Old Jan 14, 2008 | 12:43 PM
V8Rumble's Avatar
Wow - that price looked rather high at first glance, but given the other stuff that comes with it, I can see some value there. Plug & play sure must be nice...
Although, if I was going to spend that much on the harness/wiring, I honestly think that I'd send it to John @ Speartech. Nothing at all against the harness you've gotten, but he was good enough to answer a couple of questions for me last week when I needed immediate answers (found a harness on craigslist locally, needed to know if I should jump on it or not...).
That's definitely a cool setup you've got though!
Old Jan 14, 2008 | 12:48 PM
camarolvr69's Avatar
What car is it going into?
jw33's Avatar
yeah if you already have a harness then it's probably easier to get it modified and get it to work. In my case I didn't have anything and all the little stuff that came with this one will nickle and dime you to death....
Old Jan 14, 2008 | 12:49 PM
downset71's Avatar
X2 on John at speartech.!!!!!A year later and he still helps me out with wiring questions for my speedometer and tach just last week!!!!!!! Def. recommend his services
Old Jan 14, 2008 | 12:50 PM
jw33's Avatar
https://ls1tech.com/forums/showthrea...hlight=mustang
Old Jan 14, 2008 | 01:29 PM
exodus's Avatar
most definetly agreed!!
Old Jan 14, 2008 | 02:18 PM
xssive's Avatar
Those units are non programable as far as I remember correct?
Old Jan 14, 2008 | 02:49 PM
Jones'n's Avatar
Do they have one that'll run an automatic trans too?
Old Jan 14, 2008 | 04:11 PM
jw33's Avatar
I'm not 100% sure on that. My motor is mostly stock, but I'd like to find out. Where did you hear thet they were non programable?
Old Jan 14, 2008 | 04:15 PM
jw33's Avatar
It has wires in the bulkhead connector that are for MAP output and throttle position that says it is used for transmission controlers???
Old Jan 14, 2008 | 04:56 PM
forcd ind's Avatar
did gm ever offer one for ls1, ls6
that harness looks good
Old Jan 14, 2008 | 06:21 PM
xssive's Avatar
An excerpt from Hot Rod Magazine:
Controllers To Come
When this engine swap was happening, GM Performance Parts didn't have an EFI controller for the LS-series crate engines, but it does now. PN 19166567 is a new GMPP plug-and-play controller for the LS7 (PN 19166568 for the LS2). Unlike the MSD controllers, these are nonprogrammable units, meaning they come with the factory tune for the production engine. GMPP is looking into releasing programmable units for the entire LS crate-engine family, but the company doesn't have them yet. For more information on the GMPP controller, check out page 298 of the current 2007 catalog or log on to www.gmperformanceparts.com.
Old Jan 14, 2008 | 06:26 PM
jw33's Avatar
Controllers To Come
I'm guessing that means they don't come with software for tuning, but they plan on having one that does include some sort of tuning software. I see no reason why you couldn't get this ecu tuned at a shop that does tuning on late model GM stuff. I could be wrong though....
Any idea on how to tell what kind of ECU this is? It looks like a e67 to me.
Old Jan 15, 2008 | 06:45 AM
O nice... bet u will surprise a few of the hardcore 5.0 crowd.
Old Jan 15, 2008 | 09:58 PM
Quick Double Nickel's Avatar
Is it possible to adapt the kit to the LS1/6?
Old Jan 15, 2008 | 10:15 PM
v8mazda351's Avatar
xssive is correct, non-programable, no tuner will even read them as they have a completely propietery(SP) operating system. =(
Old Jan 15, 2008 | 10:32 PM
jw33's Avatar
I woner if you can reflash them or something? I see on the case it is stamped E67??? Oh well, if I decide I need to tune my motor I think I can get another E67 ecm for pretty cheap.
Old Jan 16, 2008 | 06:13 AM
Jones'n's Avatar
I don't think so, these are designed for the newer 58 tooth reluctor engines. Won't work on an older style LS1/6.
Old Jan 16, 2008 | 06:28 AM
v8mazda351's Avatar
pcm connectors are different also, from what someone told me, so unless you swap connectors, and pcm, you're stuck with stock tune
