My current state of LS1/Nova conversion
Old Apr 21, 2008 | 12:49 AM
  #101
babydeuce's Avatar
Duane,
Looks good bud, well except for the wires everywhere Is that an American Auto wire panel, its hard to tell?
You made more progress than I did, I spent 3 hours at the parts store trying to find an upper radiator hose that will work with my limited space....NO Dice on that one!
Jack
Old Apr 21, 2008 | 06:03 AM
  #102
67pete's Avatar
Try splicing in some tubing..I spliced in, in two seperate sections. The upper one is also for the steam line.
Attached Thumbnails My current state of LS1/Nova conversion-nova-pix-front-engine004a.jpg
Old Apr 21, 2008 | 11:12 AM
  #103
ssduane's Avatar
The wiring kit is a Painless kit, was new in box when I got the car, so figured I'd use it. 18 curcuit kit that has worked nicely. Ya, got some progress done, lots of wiring accomplished.
Did you ever get a chance to run the fuel system yet? Still wondering how noisey that inline pump is.
Old Apr 21, 2008 | 11:31 AM
  #104
babydeuce's Avatar
67Pete,
I will more than likely have to splice 2 together to get what I want, thanks for the advice.
Duane,
Everything is wired, but I have not primed the system yet. I got a bit lazy this weekend, and did not do anything. Hopefully next weekend I will get everything finished up and started.
Jack
Old Apr 25, 2008 | 08:43 PM
  #105
S10xGN's Avatar
Originally Posted by ssduane
Got some done stuff done this weekend. Not too much since I kinda ran outta the ol bank funds for the Nova this month already. Picked up a red top Optima battery, and now have power throughout the car. Did some more "car" wiring, dash components, relays for the harness, wipers etc... Got the power booster mounted and hooked up, brakelines ran, with exception of front right, will wait till the inner fenders come in to do that. The engine cracks over under power , but need a PCM still, which is on order, fuel system and cooling system. Enjoy.
What headers are you using?
Russ
Old Apr 28, 2008 | 11:21 AM
  #106
ssduane's Avatar
Russ
They are homemade headers. Parts purchased from www.speedwaymotors.com.
Old Sep 22, 2008 | 06:32 PM
  #107
h8tulooze's Avatar
Is there a part # for the misc. 90's and 180's from speedway? And what size did you go 1-5/8 or 1-3/4"?
Old Oct 30, 2008 | 10:21 PM
  #108
ssduane's Avatar
been a long time since I updated...........but here goes. Engine runs great, fires up, trans hooks, torque convertor snaps good. I ended up running dual trans convertors from info I got here, seem to keep the fluid cool from what I've done of running the engine in the driveway and loading the tranny/running throught gears. I had the standard 25 inch wide Summit radiator installed but found a dual flex lite fan set up for 100 bucks, brand new that was 26 inches wide so I sold the 25 inch for a 40 buck loss, bought a 200 buck Be Cool 28" for and extra 80 bucks and saved 160 on a fan setup. So I ended up saving ................ screw it, I got a bigger fan/rad and saved a few bucks. Fans kick on great, engine runs cool.
Now all I need is, throttle/cable, borgeson joint for steering, some inlet ducting and a filter.
Old Oct 30, 2008 | 10:50 PM
  #109
BBPanel's Avatar
Veteran: Marine Corps
Here is a little cleaner heater hose bypass (AutoZone p/n#4354) - pre-bent and correct hose diameters:
Old Oct 30, 2008 | 10:57 PM
  #110
BBPanel's Avatar
Why 2 trans coolers? Do you have any more pics (driver's side around steering shaft and mounts) and details on making your headers? Your rad hoses look like they fit pretty good - can you provide p/n's? Thanks. -Bob
Old Oct 30, 2008 | 11:18 PM
  #111
ssduane's Avatar
Thanks for the PN for the bypass hose.
I ran two coolers, since 1. its the only cooling source 2. its over kill 3. I have 3200 stall 2.2 str convertor and 4. its overkill.
I do have some more pictures of the headers and what I used plus mounts etc.....
I have a part numebr for the upper hose that I'll post, lower was one I found and cut.... will post more later.
Old Oct 31, 2008 | 01:16 AM
  #112
BBPanel's Avatar
...I do have some more pictures of the headers and what I used plus mounts etc.....
Sorry, I didn't mean pics of the mounts themselves but how the headers fit around the mount and steering shaft. Have LS1 in Checkered clip and looking to do headers. -Bob
Old Oct 31, 2008 | 07:25 AM
  #113
SUPERBOOST's Avatar
You probably already know about them but I just want to make sure.S&S headers list a set of ls1 headers for after market clip in chevy II now .Have'nt seen them on a car but they look pretty good.They are long tubes,The part # is 5207 if anyone needs it.You can get them plain or coated.Anyone used these or have any feedback on them?
Old Oct 31, 2008 | 02:08 PM
  #114
BBPanel's Avatar
Yes, I understand another member has them installed. I have PM'd him and perhaps he will be kind enough to come in and show some pics.
Old Oct 31, 2008 | 04:37 PM
  #115
AINT SKEERED's Avatar
this is my curreny state.
I got a set of ls7 manifolds that will have to face up and then exit to the fender wells. I am just not sure i like the way they look.
I like the header kit that was posted from speedway and I am thinking of building a set.
Old Oct 31, 2008 | 04:40 PM
  #116
Also the 6.0 liter intake is temporary. It will end up with a vic jr later on. this is a drag car and is very light with fiberglass doors, trunk and front cap with lexxan windows.
Old Oct 31, 2008 | 06:23 PM
  #117
BBPanel's Avatar
....Have'nt seen them on a car but they look pretty good.They are long tubes,The part # is 5207 if anyone needs it.
Do you have a pic - I don't find any specific pics on their website for p/n 5207. -Bob
Old Oct 31, 2008 | 09:31 PM
  #118
SUPERBOOST's Avatar
Default S&S headers
I will try to get pictures for you,it will probably take a day or two though.I will post them when I get them.
Old Nov 1, 2008 | 06:46 AM
  #119
Where have you all bought your front rack an pinions from? I am now thinking about changing that **** up from the factory steering.
What was the cost of changing to rack and pinion ? I dont want power steering either.
Old Nov 4, 2008 | 07:13 AM
  #120
JZHeyde's Avatar
Good morning fellow nova lovers.
BBpanel PM'd me asking for pictures of the S&S headers installed. I will attach a few pictures here and if anyone wants something specific please let me know. It may take a few days to get the specific picts but I will get them. My opinion of the headers is that they are of very good quality, manufactured well, and fit decently. They are VERY tight on the lower control arms and extrememly tight on the starter. Expect some serious MF'ing when trying to install the starter if the headers are already bolted on. I used header studs and they made my life a little easier. They also hang VERY low, my car is sitting on 2" drop spindles and the headers are 3" off the ground, maybe less. IF anyone has any specific questions please let me know. Thanks!
