Idler pulley relocation brackets back in stock
Old 09-12-2008, 01:05 PM
9 Second Club/LS1TECH Sponsor
Speartech's Avatar
Default Idler pulley relocation brackets back in stock
We just got a new batch of the idler pulley relocation brackets in.
These are for the LS1/LS6 intakes swapped onto the Vortec truck engines (4.8, 5.3, 6.0).
The brackets are $85 each plus shipping. We've had some problems keeping these in stock, so get 'em while we got 'em!
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old 09-12-2008, 03:15 PM
dsrour's Avatar
Why would you need to relocate idler. Thanks
Old 09-12-2008, 04:09 PM
pillboxesghost's Avatar
Default Look at the throttle body
Check the relationship of the throttle body to the H2O pump pulley in the last two photos.
The truck intake locates the throttle body much higher than the passenger intakes do.
When you move the TB down the belt (idler pulley) must be relocated slightly to allow the belt to clear. That is, if you want to keep the stock truck alternator mounting.
Old 09-15-2008, 08:53 AM
Speartech's Avatar
As stated above, when you install the lower intake manifold (LS1/LS6/Fast) the throttle body will hit the idler pulley if it is not relocated.
Our custom bracket gets the pulley out of the way. Most of the truck guys that are making the intake swap don't want to change the whole bracket set, so this lets you keep the alt., A/C, etc.
__________________
www.speartech.com
Old 09-15-2008, 11:12 AM
dsrour's Avatar
Thanks!
Old 09-16-2008, 02:54 AM
70Nova SS's Avatar
Do you sell brackets for a Sanden 508 A/C compressor to mount high on the passenger side and if so how much?
Old 09-19-2008, 07:36 AM
Speartech's Avatar
No, can't help you on that. This is the only bracket we carry.
__________________
www.speartech.com
Old 09-19-2008, 10:42 PM
JIMB's Avatar
Default LS1 intake
Do you offer the water pump mods?
Jim B.
Old 09-21-2008, 09:39 PM
extremetoy's Avatar
sent a pm
thanks, Gary
Old 11-26-2008, 02:11 PM
Speartech's Avatar
All sold out again.
I'll get some more made. It takes a while for them to come in, but well get 'em.
Thanks.
__________________
www.speartech.com
Old 11-27-2008, 11:50 AM
pcmcobra's Avatar
how did i miss this?
Looking forward to next batch.
Old 02-18-2009, 01:34 PM
GIZZ's Avatar
Hi,
i just ordered l92 heads for my lq4 6.0, im guessing ill need the clearance for using the ls3/l76 intake manifold. i pulled the stock belt over to about the position in your pic and it looks a little short. does stock belt work or is there a longer one you need? do you have stock of the bracket again?
Old 02-23-2009, 09:58 AM
Speartech's Avatar
Using this bracket does require a longer belt.
We don't have the brackets back in stock yet. I'll post here when we do.
__________________
www.speartech.com
Old 05-29-2009, 05:10 PM
Speartech's Avatar
Back in stock!
A new batch fresh from the oven.
__________________
www.speartech.com
Old 05-29-2009, 05:46 PM
Indyjc's Avatar
John was wondering if you have your 91 Z up and running?
Old 06-01-2009, 11:53 AM
Speartech's Avatar
Yes, it's up and running. I don't get much time to play with it it, but it's running fine.
More upgrades planned for the near future!
__________________
www.speartech.com
Old 08-03-2009, 02:51 PM
glock35ipsc's Avatar
I see the two water pumps are different. What is the replacement water pump in the pic with the car manifold? And was a pulley change needed?
Thanks!
Old 08-03-2009, 03:24 PM
Shon Herron's Avatar
Thanks!
the pulley is the same on the truck or car WP, so you do not need to change it, just need to get a car WP.
Old 08-03-2009, 04:15 PM
Speartech's Avatar
The pulley on the truck and car water pumps are completely different!
__________________
www.speartech.com
Old 08-03-2009, 04:24 PM
I kind of thought so. So what is the pump and pulley application in this pic?
Quick Reply: Idler pulley relocation brackets back in stock
