engine starts to tick after 15 minutes of driving ls1 240sx
so the engine started the tick the other day after driving for 15 minutes. I came on here and searched and found a few threads that said to check my spark plug wires, i bought new plug wires and bam problem solved..... or so i thought. The tick came back again today and sounds like a bad lifter. Every time i search on here about lifters and ticking noises people say their lifters make noise on start up and goes away after a while, mine is the exact opposite. so if anyone knows what this problem is please let me know, Thanks.
i had lifters go out in 3 different motors and it was louder than a tick..... are u sure its not an exhaust leak ? did u re-use the the header gaskets? just a thought.... hope it helps.....
i just finished the swap and do not have an oil pressure gauge, the guy that tuned my car with hp tuners said the oil pressure looks good and it runs great besides the ticking. does anyone know how i can hook up a autometer mechanical oil pressure gauge to this ls1?
"does anyone know how i can hook up a autometer mechanical oil pressure gauge to this ls1?"
You can drill/tap the crossover/blockoff plate at the dr side/rear of the engine block. There's a nipple sticking out on that plate. You can remove the plate, and do the tap. Street & Performance has an adapter fitting for this mod.
do you still have that little air box on it? i cant remember the real name. its between the intake and driver head. little bigger then a medicine bottle, black.
mine ticks too and i tracked it back to that. mines cracked so i think it louder then normal. maybe the same on yours.
